Old chesscold fridge
Submitted: Wednesday, May 06, 2020 at 18:18
Lyndon M
Hi folks
Just bought an old chesscold f40 3 way fridge just to have as an extended stay
camp fridge to keep the beer cold. First tried it out on gas as this would be what I would be using it on mostly lite first time and got cold after a couple of hours but froze everything solid the temperature control does not seem to do anything. Next tried it on 240 been on all day but nothing the element must be working as I can feel the heat at the back. Know this is going to turn into a restoration project. Does anybody know if you can still get parts for them. Thanks
Reply By: peteC - Wednesday, May 06, 2020 at 19:04
I have one of the 50ltr thats over 30 years old.
12volt - forget it, may and say may just keep temp, drawing huge amps
240 works good
Gas works very good. You would use 9kg bottle in about 7-10 days
About the temp control - on lowest possible will do as fridge. Move off the min and you are talking freezer.
Not sure why its not cooling on 240v when you have heat, but it works on gas. Try shutting down then turn upside, sideways etc for a while in each position
631382
Reply By: Darian - Wednesday, May 06, 2020 at 19:16
As I recall with
mine, years back...gas is the star performer, 240v is adequate...12v is only of use while mobile, with a pre-chilled fridge (and supported by the tug’s alternator...as mentioned, the 12v cycle draws a lot of power). As mentioned above, tipping the fridge right over, to and fro sideways will stir up the fluid and can be useful as a tactic. Also, I think the thermostat only works on the gas cycle...probably, the 12 and 240 are just ‘on’.
631383
Reply By: Allan B (Sunshine Coast) - Wednesday, May 06, 2020 at 20:13
As an aside, long ago I undertook a refrigeration mechanic course during my electrical apprenticeship. We spent most of the year studying compressor systems, then finally we got to domestic absorption fridges which were then powered by a kerosene flame.
We studied the principle of operation then the instructor got to troubleshooting. I can remember his words still today............ "The best advice I can give you is to take it out onto the back lawn and roll it around for a while. Put it back into the kitchen, come back next day, and by the Grace of God it may be working."
In 70 years, nothing's changed.
631384
Follow Up By: Banjo (WA) - Thursday, May 07, 2020 at 09:11
Is that advice for the fridge, or the missus?
907406
Reply By: Rangiephil - Thursday, May 07, 2020 at 10:23
A computer fan trained on the heat exchanger across the back will improve its 12volt performance.
Mine used to (slowly ) make ice in its teeny ice tray while on 12v.
I had a Gruen many years ago which I think is similar to a Chescold.
631387
Reply By: Mike C9 - Thursday, May 07, 2020 at 12:43
Hi Lyndon
Apprently Caravans Plus carry some Chescold parts. Have a look
here
Mike
631389
Reply By: Lyndon M - Thursday, May 07, 2020 at 18:37
Thanks for all the advice got it going on 240 now seemed to be just because it was a bit out of level can’t believe now level they have to be to work. Sounds like I’ll put the temperature control in the to hard basket just be happy it’s cold. Would it still be a good idea to turn it upside down? Thanks again.
631394
Follow Up By: Zippo - Friday, May 08, 2020 at 11:17
NO. Don't poke the bear.
Even from your first post where you said it was working/freezing on gas, it was very obvious the coolant was in the right place and not the cause of the problems.
907451
Follow Up By: OzzieCruiser - Friday, May 08, 2020 at 11:34
Yes give it a good shake up and a roll around to get those fluids properly mixed - it will then work very
907455
Follow Up By: Allan B (Sunshine Coast) - Friday, May 08, 2020 at 12:21
The issue is not "mixing fluids"........ It is eliminated a vapour lock by agitation.
907461
