Sunday, Apr 26, 2020 at 12:18
That vehicle seems to be very tidy, but with the km's it has done, I would be getting it thoroughly checked over.
I have a 2010 LC200 60th Anniversary set up as a long distance tourer. Uses next to no oil. I stand corrected, but I think around 2010 Toyota fixed the oil usage issues?
Mine has only 115K on the clock. As someone stated, 256K is getting up there for time to replace injectors, although some have had to be replaced a lot earlier than that. 8 x LC200 injectors will be around $4000 for non genuine, more for "genuine" Toyota, plus fitting & labour etc. Just something to consider. They are expensive vehicles to maintain. (I have just replaced the power steering pump on
mine!!)
Also as stated, make sure the injector feedback values are checked. That should give a reasonable indication as to the state of them. Someone mentioned turbo squealing as a
sign of stuffed turbos - that might have been the case in the scenario stated but you will find that most if not all 200 series have a distinctive turbo noise likened to a squeal and not the "normal" "sweet" turbo whistle we are all used to. (under load around 1500 to 200 rpm) That is just the way they are. It used to annoy the hell out of me, but you get used to it. There are a number of posts on for example the LC200
forum relating to this. It is a bit like the transfer gear noise on the 200. Distinctive whine in low range but totally Ok & "normal"
Along with any IFS vehicle, the 200 is no stranger to busting CV's. There are plenty of examples on
forum posts you can find of 200's driving uphill, front wheels spinning, lifting in the air and coming back down onto the ground and bang. Again, no different to most other IFS vehicles. Perhaps not super expensive to fix/replace, but off road in the middle of nowhere without the parts/tools/know how to fix creates a problem. I am especially careful with my vehicle when off road.
Dusting is an issue that has raised its head more so lately and it is not particularly specific to the 200 series. It is caused by a not so good fitting of the lid on the airbox. Another thing to check on inspection. Lift the lid and check the "clean" side for dust on the inside of the lid and ducting to the turbos. I am keeping a close eye on
mine. I have had small amounts of dust in
mine but hopefully not enough to do damage. Fingers crossed !! A fix is to replace the factory airbox with a aftermarket one, but they are not cheap. Depends on how much you want to fix the issue I suppose.
Price wise, it looks around the right money, dependent on what you see on inspection - the k's are getting up there but perhaps average or a bit more at 25K per year.. The vehicle was probably around $80-85K new, plus it has the "extras" fitted now, although if traded, those extras would get you sweet-b-all extra from a dealer. Disclaimer - I am no expert on car valuations !!!
The LC200 is a great vehicle, especially for touring, but they are a heavy beast. The payload given is lousy and unless you have a GVM upgrade, it is very very easy to exceed the GVM (hence the reason
mine has a GVM upgrade). Fuel consumption wise, being so heavy, is not what I call great. On
mine, weighing in at about 3.5t loaded, I can get around 13l/100k on a trip, around town about 16 and when towing 2.6t, around 18-20 - give or take.
There are probably other little quirks that the 200 has, but all in all, I love
mine and hopefully it gives me years more of good service.
Hope that all helps.
631228
