OziExplorer for Android - Update (Version 1.34) released
Submitted: Friday, Apr 10, 2020 at 19:48
ThreadID: 139898 Views:12510 Replies:0 FollowUps:0
Hello - Just notice that just ~2 weeks after the last update a new update was made available..possibly due to a new version of Android being released. Must be fun being a programmer :)
Ozi Android Page
Updates:
Have increased the minimum version of Android supported to remove the message "This app was developed for an older version of Android" (message appears in Android 9 and 10). OziExplorer now supports from Android Version 4.1 upwards.
Android 10 has forced a new New Device ID method to be developed. The previous Device IDs will still be used where possible for checking the license so old/current licenses should still be valid even though the displayed Device ID is different.
Supports new permission system for Android 6 and above - permissions are requested at runtime.
The Last map zoom is now remembered when app is closed and restarted.
Better visual support for high density screen devices. This means objects such as waypoints and moving map point will now appear larger on high density devices - this can be adjusted in configuration.
Added support for loading GPX files through screen designer (new version of screen designer V1.14 required).
Added ability to download and install OziExplorer update direct from the app (from this version on).
The state of OziExplorer (last map, odometer values and other on the fly settings) are now saved when changed instead of only saving when exiting the app
The Map name in the action bar (title) is now the map name instead of the map file name.
Removed SMS messaging option from this version (for now anyway).
Fixed crash which would happen occasionally when rotating device.
Many other bug fixes.
