Brisbane to Lawn Hill NP
Submitted: Wednesday, Feb 05, 2020 at 07:03
DazAthorn
Hi all, I'm not sure if this is the correct spot or Avenue to ask this info but I am solo riding (2011 VStrom 1000) from
Brisbane to
Lawn Hill NP in July this year to meet friends and am after any relevant info that people may have. This could be best routes, road conditions,
places to see, etc. At this point I'm looking at weaving my way diagonally through central QLD to
Camooweal then up however have just seen some reports saying there is a couple of really rocky river crossings that way. I'm now a bit hesitant doing that when riding solo. Anyway, any advice would be extremely welcomed and greatly appreciated.
Thanks.
Darren
Reply By: Athol W1 - Wednesday, Feb 05, 2020 at 11:59
Darren
I agree with the previous answers to your question.
I have been there a number of times over the years and have used all the available roads, but not for about the last 4, and I would suggest you look at
Cloncurry to
Bourke & Wills Roadhouse, then
Gregory Downs to
Lawn Hill. This is a sealed road to
Gregory Downs, then a usually
well maintained dirt to the turn off to the
mine site, and could be anything gravel from there.
This will give the shortest distance to travel on poor roads.
Enjoy your trip.
Athol
629904
Follow Up By: DazAthorn - Wednesday, Feb 05, 2020 at 18:08
Brilliant! Thanks so much for the info Athol.
905063
Reply By: Zippo - Wednesday, Feb 05, 2020 at 12:33
We went from
Normanton (because we were there!) across to
Burketown,
Gregory Pub to
Lawn Hill (just after the fire destroyed a lot of the Adel's Grove
infrastructure). The only bit that wasn't good/black_stuff was the bit after
Gregory - started decent, then the seal was broken and holey, degenerating after the minesite to serious corros.
Leaving Boodjamulla NP (Adel's Grove) to the SOUTH via
Riversleigh was rough until meeting the
Gregory to Barkly Hwy road, then decent all the way down - but probably still a better bet than back to
Gregory. FYI there's a watercourse (Louie Creek) about 10k down which lunched a Mitsubishi van engine when he was crawling through it. Knee deep usually, uneven rocky bottom, not sure how your laden bike will deal with it. There is more water across that road further down, but bitumen/concrete crossings and not deep or any concern.
Ex Brissie I'd be thinking the direct route -
Barcaldine -
Winton -
Cloncurry -
Gregory
629907
Follow Up By: DazAthorn - Wednesday, Feb 05, 2020 at 18:12
That's exactly the info I am looking for Zippo. Thanks heaps. Pretty sure I'll take the more direct route.
905066
Reply By: RMD - Wednesday, Feb 05, 2020 at 13:51
Daz,
Apart from the road and crossing info supplied what mods, alterations or precautions have you made/done to the Vstrom, a good bike!
I owned an '08 DL1000 for ten years and saw some on the
Oodnadatta track in 2010. One fellow crashed and was badly hurt and a doctor in the group riding a 1000 Vstrom slid off on sandy marble surface and broke gear lever and other bits. Unrideable unless prepared with spares or really savvy with bikes. Just the OE front Tyre will be great for bitumen but any gravel and other situations really requires a very open tread on the front at least. If you EVER have to brake hard Oe tyres on gravel and sandy stuff just don't cut the mustard in emergencies. Riding solo you want to have things a bit in your favour. Comfortable and a good bike, having the
suspension raised a bit and the rear adjusted to handle the load will ensure some vital clearance in sudden unexpected dips which bottom the
suspension unless prepared prior to travel. You didn't mention your bike experience or mechanical capabilities so some suggestions worth considering supplied here. I have owned a series of large capacity trail bikes as
well and ridden bikes more than 200,000km. PS, A BMW R100GS I owned was by far the thirstiest and the worst bike, handling, braking and
suspension very sub standard, as for reliability,
well we won't mention that. Only two good days with that one, purchase day and selling day. Vstroms will do 250,000km and not give trouble.
629910
Follow Up By: DazAthorn - Wednesday, Feb 05, 2020 at 18:26
RMD....thanks so much for taking the time to write such a lengthy response. All absolutely critical info and appreciated. To be honest I wouldn't have thought to pack a spare gear lever but will now. Such a small piece but so important.
As far as mods go, I will be putting on new tyres for the trip (at LEAST 50/50 tyres), have replaced the stock hand guards with bark busters to protect the levers, have crash bars and a sump guard. My mechanical skills are pretty basic so will be prepping the bike as
well as I can but I think I know enough to get me out of reasonable trouble. I'll also be getting my mechanic to do a full inspection prior to leaving.
As far as
suspension goes I'll utilise the adjustability of the rear preload once loaded but don't think there's much I can do up front excluding an upgrade.
I seriously appreciate the advice you've passed on here RMD and will definitely make use of it.
Thankyou!!!
And if you think of any other information please don't hesitate to pass it on.
905067
Follow Up By: RMD - Thursday, Feb 06, 2020 at 08:16
Daz
I removed the OE luggage carrier, too small and pretty useless for touring, and made a much wider longer rack with bag hoop bolted to the top. It bolted to OE points. That way my gear bag, when touring, could be rotated to the front and became a back rest too and the larger rack I made used for additional gear. Tent, food sleeping bag etc. I still have that, I kept it when bike sold. Available for someone if they require it. I added a switch on the battery and wires run in fairing along inside, to a ciggy outlet so reaching through the steering gap a navigator/GPS could be plugged in and used on the clear screen mounts. I also added side LED indicators, tapped off wring to front indicators so when pulled up at intersections, drivers can see a side flasher to know where you are going. Got stopped one day by Head of Vic Police bike section and he asked about them and then had some fitted to theirs. I carried 1 Litre of additional fuel in an aluminium drink bottle as insurance. There are a lot of steps in a litre of bike fuel. If going through rocky crossings, boots off, runners ON and walk beside for surety, simply riding through unkown slippery rocks will unload everything, then it is recovery and what you lost in the water is lost.
905070
Follow Up By: DazAthorn - Thursday, Feb 06, 2020 at 22:58
Your custom rack sounds very interesting. You wouldn't have any pics of it would you? Might make one similar
905081
Reply By: Shane M11 - Thursday, Feb 06, 2020 at 18:37
Hi Daz,
Maybe have a look at this site
https://advrider.com/f/forums/australia.32/
There is a thread about V-Stroms in there with heaps of info and recommendations about tyres and gear etc.
Also the second weekend in August the Off Centre Rally is on at Adels Grove there will be nearly 200 riders attending. Thread here
https://advrider.com/f/threads/ocr-2020.1379244/
You could easily find some traveling mates if this suited your time frame.
If you do travel alone think of carrying a personal epirb or a spot tracker or similar.
Biggest thing when travelling alone on the bike I found is as soon as you realise your not focused even for a moment stop and have a break. That's when you'll get caught out - don't ask how I know.
Shane
629923
Follow Up By: Member - shane r1 - Thursday, Feb 06, 2020 at 20:49
Totally agree with being focussed , Shane.
Part of that is hydration, it’s so easy to not drink enough on a bike . And food too!
When you dehydrate your concentration suffers, then mistakes happen.
Hope you didn’t get too badly busted up!
Carrying a spot (which I do) and have family/friends watching you is a great idea, has been plenty of discussion on this
forum about that!
Safe travels Daz, have fun
Shane
905079
Follow Up By: DazAthorn - Thursday, Feb 06, 2020 at 21:21
Thanks gents. Definitely agree RE the hydration and rest stops. I'm planning to make the ride as big of a part of the experience as the destination. Looking to take 5 or so days each way and stay for 3-4 days. Trying not to rush and take plenty of breaks.
I'm going to try to work a water bladder into my tank bag so I can continually sip and stay hydrated.
Looks like I'll miss the rally by about 3-4 weeks....bugger. That would have been great! I'm leaving Bris on around the 11th or so of July.
Again, thanks heaps for the info and advice guys. It is hugely appreciated. I most certainly didn't expect so many responses. This is such a great
forum!!
And yes I'm definitely going to be carrying a Spot or equivalent. An absolute must when solo I reckon
905080
Follow Up By: Frank P (NSW) - Sunday, Feb 09, 2020 at 13:55
"I'm going to try to work a water bladder into my tank bag so I can continually sip and stay hydrated."
Would a camel pack under or over your jacket be practical?
905159
Follow Up By: DazAthorn - Sunday, Feb 09, 2020 at 14:11
Yeah definitely an option for a camelback but I was just trying to keep any excess weight off my back for such a long trip
905160
Follow Up By: Member - shane r1 - Sunday, Feb 09, 2020 at 14:41
Daz, just water in a back pack isn’t bad , as it gets lighter as you go anyway. I have mesh type jackets with bladder compartments incorporated. Work great.
ShanrR
905163
Follow Up By: 9900Eagle - Sunday, Feb 09, 2020 at 14:48
Dazza, I think you will find he is referring to the Thorntonia - Velvertoft rd which is around 120 K our of the Isa which is pretty good.
If you go via The Curry to
Gregory downs and onto Lawnhill all good and if your lucky the road from
Gregory downs to Lawnhill may be in better condition, as they have opened up Century
mine are are reprocessing the tails
dam, just be aware that road trains maybe be operating carting cattle if you travel that section .
905164
