Battery terminals
Submitted: Friday, Jan 03, 2020 at 14:07
Dana M2
Hi all & a Happy New Year ??
Got another question?
Bought a Deep cycle battery for my 80, and the terminals are on opposite sides.
Any thoughts as to what I should do?
I have though of just changing out the terminals so they are longer.
What are you thoughts guys?
Dana
Reply By: Member - Stephen L (Clare SA) - Friday, Jan 03, 2020 at 14:11
Hi Dana
Are you able to either return the battery to get one with the correct terminal positions.
There are made that way so in the event of an accident, the positive terminal is not going to short on the body of the vehicle, and possible fire risk.
Other will have a better explanation.
629312
Follow Up By: Dana M2 - Friday, Jan 03, 2020 at 14:32
Hi Stephen
Will see if we can get an exchange and get back to you?
904101
Reply By: Member - Racey - Friday, Jan 03, 2020 at 14:31
Agree with Stephen; change it.
629313
Follow Up By: Dana M2 - Friday, Jan 03, 2020 at 16:12
Thanks everyone
Was an easy fix
Just exchanged the battery
904104
Reply By: Allan B (Sunshine Coast) - Friday, Jan 03, 2020 at 14:44
Hi Dana,
You should be able to exchange as Stephen suggested, but if not then read on.......
When you say that the "terminals are on opposite sides" I presume that you mean they are reverse to the original battery and that the cables will not reach to the appropriate terminal. Is that so?
If the battery is turned around, end-for-end, will the cables still not reach? If so they must be very short cables.
What are the battery terminals? Are they lead posts about 18mm diameter, or are they threaded holes that accept 8mm bolts?
What do you mean by "changing out the terminals so they are longer."?
If you can answer the above questions I may be able to advise you.
629314
Follow Up By: Dana M2 - Friday, Jan 03, 2020 at 16:14
Hi Allen
Thanks for your response
Was an easy fix
Just returned the battery and they gave me the correct one.
Thank you
904105
Follow Up By: Allan B (Sunshine Coast) - Friday, Jan 03, 2020 at 16:15
Good one Dana.
904106
Reply By: RMD - Friday, Jan 03, 2020 at 17:29
Dana
Do you mean replace the terminals or the leads? Not sure what "changing out means". In the same situation the battery can be end for ended and the cables crossed as an option. An AGM isn't good under bonnet because of applied radiant heat. Can you keep it cool somehow. .
629319
Follow Up By: Dana M2 - Friday, Jan 03, 2020 at 19:24
RMD
All sorted
Just changed the battery
904121
