227 locking drawer slides
Submitted: Saturday, Dec 28, 2019 at 17:43
ThreadID: 139460 Views:7699 Replies:5 FollowUps:0
I purchased some 227kg drawer slides and was wondering if there is a trick to getting them apart to mount them to the framework/ carcass before you mount the other part to the drawer. I’m using plywood and I got them from Dunn and Watson. Thanks
Reply By: Member - Racey - Saturday, Dec 28, 2019 at 18:25
You don't need to separate them, just slide them open and attach the draw to the inner slide on both sides then attach the main part to your frame. This is what I did.
Jon
AnswerID: 629236
Reply By: 1533rl - Saturday, Dec 28, 2019 at 18:49
If you do want to seperate the two parts, extend the slide to full extension and on the outer part , half way out, there will be a small black plastic lever. The slides are opposite set, so one lever goes up and the other goes down. Move the lever and pull the inner part, the one which attaches to the drawer, out from the outer part of the slide. To reattach, just line up the two parts and push together.
AnswerID: 629238
Reply By: Phil G - Saturday, Dec 28, 2019 at 21:57
The 227kg do not come apart. It does not have the plastic tabs like the 125kg and smaller
There will be holes in the slide you need to line up to put the screws or rivets in
AnswerID: 629242
Reply By: Keith B2 - Sunday, Dec 29, 2019 at 10:55
I have installed two sets of these slides with a heavy weight on them and they failed both times. So do be aware that the actual working load is vastly less than the 227kg claimed.
Keith
AnswerID: 629246
Reply By: nickb - Sunday, Dec 29, 2019 at 16:38
Some come apart and some don’t. As above they usually have black tabs to release the slides, otherwise just move the slide out to line up the mounting holes.
Note that the 227kg is only in the closed position. At full extension it would lucky to be half of that. The specs usually have a table or graph showing weight limits at different extension lengths.
AnswerID: 629251
