Monday, Nov 18, 2019 at 16:08
Batt's,
The advice to let stand for a period after unpacking relates to compressor oil collecting in unwanted locations if the fridge should have been on its side. This goes back a long way in time for all fridges and is less often advised today due to reduced oil volume and fridge design. Neither Engel nor Waeco mention it in current user manuals.
Maybe Brass Monkey is being old-fashioned or over cautious. Their expression would not give me concern.
The Brass Monkey manual states that the fridge can be operated at up to 45 degrees tilt for short periods and up to 5 degrees for long periods. I would expect those limitations would be satisfactory for off-road use. The fridge is marketed for vehicle use.... BM would be in deep trouble if it could not handle a bit of rock'n'roll.
The same manual specifies ventilation as "200mm at back, 100mm at sides". I could not determine where the "back" is but I would presume that the greater dimension should be where the condenser air vents are.
The Engel OWNER MANUAL specifies "6 inches (150mm) clearance" on all sides, so that is greater than the Brass Monkey. The Engel SERVICE MANUAL deals more specifically with ventilation using a diagram to show the cabinet air vents and the required air path. This is more appropriate advice as it is important that the expelled hot air is not drawn back through the inlet path.
903197
