Rear tow point
Submitted: Tuesday, Nov 05, 2019 at 20:57
ThreadID: 139286 Views:10331 Replies:8 FollowUps:10
Hello,
I have a prado 150 and don’t have a towbar and not planning on getting one. I am wanting a rated recovery point on the rear I can use for recover tow/ snatch.
I have searched and have not found anything for this.
I have road safe recovery points on the front.
Interested to hear what others have done.
Brent
Reply By: Bazooka - Tuesday, Nov 05, 2019 at 22:15
I have a tow bar Brent but this thread on Pradopoint might help.
Prado Rear Recovery
AnswerID: 628550
Reply By: Member - willawa - Wednesday, Nov 06, 2019 at 08:06
Hi Brent
Try Shannon at Rally Speed Artarmon . They may be able to help
That is if you'r in Sydney
Ed
AnswerID: 628553
Follow Up By: Brent N2 - Sunday, Nov 17, 2019 at 12:12
Thank you I tried Shannon but no luck
FollowupID: 903160
Reply By: Hoyks - Wednesday, Nov 06, 2019 at 15:48
Why wouldn't you be interested in a tow bar?
It will be an easy bolt-in solution that will work as an additional chassis cross member to spread the load between the rails as well as give a solid lump of metal to bump on rock steps before the expensive plastic and work as a solid recovery point.
It also gives you the option to tow if the need ever arises.
If $$ are the issue, and you have no plan to tow a trailer, then you can pick up a unblemished tow bar from the wreckers, bolt it in and not worry about the trailer plug wiring.
AnswerID: 628556
Follow Up By: Brent N2 - Sunday, Nov 17, 2019 at 12:13
I am going to fit a Kamar or other rear bar in the future which will have tow bar included
FollowupID: 903161
Reply By: Ron N - Wednesday, Nov 06, 2019 at 15:59
One of the things I enjoy as regards having a towbar fitted to every vehicle I have ever owned, is - when some brain-dead dropkick, yapping on his phone, texting, or otherwise indulging in totally distracted driving, runs up the back end of your vehicle at speed - the damage to your vehicle is minimised, and the damage to the dropkicks vehicle is increased.
I've had 4 of these style of imbecile drivers, run into the back of 4 of my vehicles (in the last case, I was parked in the Missus' Camry, in a clearly-marked parking bay, in front of a cafe, at midday on a bright, sunny, dry day - and a dropkick in a Commodore ran straight up my back end at 60kmh, without even hitting the brakes) - and in every case, I was able to drive away, whereas the offending drivers vehicle had to be towed away, with very major front end damage.
Cheers, Ron.
AnswerID: 628557
Follow Up By: Batt's - Wednesday, Nov 13, 2019 at 17:35
If your tow bar has a removable hitch like a Haymen Reese style one day maybe one of those dropkicks will notice it then you will be up for the cost of repairs as it's illegal to leave it in place when not in use and your insurance won't cover it..
FollowupID: 903096
Follow Up By: nickb - Friday, Nov 15, 2019 at 22:54
If you can find any evidence in the history of time where insurance has been declined due to leaving the tow bar tongue in, I’ll walk on water. I’ll add to that, I’ll keep my end of the deal if it happens within the next 50yrs too. It may well be illegal but I reckon you have as close to zero chance as you can get where insurance will be voided for the sole reason of your towball tongue is in when not in use.
FollowupID: 903145
Follow Up By: Ron N - Sunday, Nov 17, 2019 at 13:07
It's not actually illegal to leave a tow hitch in place if you're not using it.
What the law does say, is, you are not allowed projections on a vehicle that may injure pedestrians if you accidentally hit one.
Obviously, the law is designed to apply to the front of vehicles, and it would be open to challenge in court if you were booked for having a tow hitch installed, and you weren't towing something.
I've been hit 4 times up the rear in 55 years of driving, and every time, I had a towbar and hitch fitted (with nothing attached) and each time, the insurance company paid out, without complaint.
What I did find, was that every driver that ran up my rear, produced a false name and address!
The last idiot even produced the name of a bloke that was in jail that particular day! - and had the hide to tell that to the investigating police!
Cheers, Ron.
FollowupID: 903162
Reply By: Member - Barry P (VIC) - Wednesday, Nov 06, 2019 at 19:18
contact the 4wd shed in bayswater melbourne they might have something
AnswerID: 628561
Reply By: Bob Y. - Qld - Thursday, Nov 07, 2019 at 06:50
Check out Superior Engineering, in Deception Bay Qld. They make heaps of similar stuff for 4wds, just not sure about rear tow points.
AnswerID: 628568
Reply By: CSeaJay - Thursday, Nov 07, 2019 at 17:41
The best rear tow point, and the safest, will be a towbar...
AnswerID: 628575
Follow Up By: ian.g - Sunday, Nov 10, 2019 at 12:57
Will be the cheapest also
FollowupID: 903044
Follow Up By: Nomadic Navara - Monday, Nov 11, 2019 at 08:27
And it is the best way of spreading the tow force between the two chassis rails. This is a very important point. Why the aversion to fitting the correct equipment?
FollowupID: 903052
Follow Up By: ian.g - Monday, Nov 11, 2019 at 13:06
Who's to say it's not correct and not spreading the tow force evenly, it is after all a "Tow Bar" a lot of design goes into producing them and they are model specific.
FollowupID: 903057
Follow Up By: Nomadic Navara - Monday, Nov 11, 2019 at 13:46
I don't get your gist Ian. Are you insinuating that I am saying a tow bar does not distribute the towing force evenly to the chassis????????????????
FollowupID: 903060
Follow Up By: ian.g - Monday, Nov 11, 2019 at 14:07
I thought that was what you were saying, however on re reading your post I see that I was wrong, and I apologise. The "Why the aversion to fitting the correct equipment?" was what confused me, once again sorry.
FollowupID: 903062
Reply By: Allan B (Sunshine Coast) - Thursday, Nov 07, 2019 at 19:24
Hi Brent,
There appear to be very few, if any, commercially offered rear recovery points. The reason for that is probably little demand as most people have towbars which easily perform that task.
Another consideration is that it would be necessary to attach a rear recovery point to the chassis at much the same place as where a towbar would be attached. This is in a rather inaccessible location and would be somewhat difficult to access to attach recovery straps and the strap could come into contact with body parts when in use.
In my own case, I added rated recovery hooks to the towbar arms in an accessible but concealed position which allows for the use of an equalising strap if so desired. But I have never needed them!
There is no need to have the ball mount fitted, leaving the hitch box available to connect a tow strap.
AnswerID: 628577
