Running a 240 volt fridge via an inverter.
Submitted: Tuesday, Oct 29, 2019 at 10:02
Best Off Road
Hi Folks, I haven't been on here in ages, but recently bought an old Cabana Caravan to take the grandchildren
camping. Anyway, I thought I'd share this
Running a 240 volt bar fridge from a 12 volt battery via an inverter when off
grid. Firstly whilst I don't claim to be Collyn Rivers, I've been around 12 volt
camping stuff for years, own a related business and used to fit dual battery systems. Given I had the gear kicking around I put it to the test.
I have an old Varta 100 amp AGM that is a bit tired but not too sick (it will hold 12.75 volts wheras a new fit one will hold 13.0). I ran the fridge (an old 90 litre NEC cheapie that came with the van) on 240 yesterday filled with cold stuff. At 8pm I plugged the fridge into the inverter and ran it overnight. At 8am today the battery (standing voltage) was at 12.2.
I then plugged in the 300 watt solar panel setup and continued running all day via the inverter on a miserable
Melbourne day. The sky as you see it in the photo was pretty much how it was all day with regular rain. I shut it all down at 6pm and let the battery settle, it showed 12.42. In effect on a very solar unfriendly day, the solar had run the fridge and inverter, and had "banked" about 20 amps.
Running a 240 volt fridge from 12 volt through an inverter is highly inefficient compared to running a proper 12 volt compressor fridge. However if you have sufficient solar it can be done. Certainly on a day with as little as two hours sun and the rest of the day overcast, with this setup it will work.
Note, the inverter is a Giandel 1000 (2000 surge) watt pure sine wave unit which are only a bit over $100 these days. The 300 watt solar gear was $175 from Ebay. I added 15 meters of 6mm wire (about $40) as it is essential to be able to chase the sun to get best solar results. A big change from 2004 when I paid $750 for a 64 watt solar set up.
Sky
Van and Panels
Reply By: Notso - Tuesday, Oct 29, 2019 at 10:54
Yes, that's something I looked at doing a while back. A lot of these little bar fridges only use 60 or so watts. As long as the inverter can handle the start up draw.
Discussion on this topic
628394
Follow Up By: Best Off Road - Tuesday, Oct 29, 2019 at 12:02
Yeah, tried it on a 600 watt modified sine wave years back at it wouldn't start. Apparently 240 fridge compressors like clean power and plenty of it.
902747
Follow Up By: Notso - Tuesday, Oct 29, 2019 at 12:19
Yes, it's the start up current that uses the current, once it settles down it'll draw the specified watts. I never actually did it but thought it was feasible.
Inverters are very efficient these days and Pure Sine Wave has come way down in price. I don't think a Modified Sine Wave would do the trick.
902749
Follow Up By: Kazza055 - Tuesday, Oct 29, 2019 at 13:46
Plenty out there doing this now and I will go this way if my 3 way fridge dies.
Mostly that are fitting inverter fridges around the 200 - 300 litre and have them running on small 300w
inverters.
Much better cooling and at a much cheaper price.
902755
Reply By: SCUBADOO - Tuesday, Oct 29, 2019 at 13:50
About 10 years ago we fitted a 120l cheap bar fridge to our camper. A 600W PSW inverter JUST started the fridge. 1000W would be a more logical choice. A modified sine (square) wave inverter caused so much rumbling and growling from the compressor motor that it was obviously unwise to continue down that path.
Our $NZ700 255l Samsung Digital Inverter mains fridge running via a $100 300W PSW inverter has now survived 5 years of full time travel. It has never been turned off. Average current draw over that time from our 13V nominal setup has been 2.45A.
Replacing the original 175l Dometic 3-way has saved us $5000 in LPG refills and counting.
628400
Reply By: Mikee5 - Tuesday, Oct 29, 2019 at 15:56
I am ignorant about soft start modules but will one of these reduce the start up demand from a fridge motor?
628403
Follow Up By: SCUBADOO - Tuesday, Oct 29, 2019 at 16:24
I did try soft start circuitry both commercial and home-brew 10 years ago on the bar fridge with not a lot of success Mike.
The best that I could manage at the time made the difference between the 600W PSW inverter JUST starting the fridge and making it a little less stressful. A 500W unit never worked. It was not worth my effort. Perhaps others have had more success?
A larger inverter was a more reliable final option.
902763
Follow Up By: Best Off Road - Tuesday, Oct 29, 2019 at 17:01
Decent PSW
inverters are that cheap these days it's the easiest way to go. And it will run a two slice toaster LOL.
902768
Follow Up By: Member - rocco2010 - Tuesday, Oct 29, 2019 at 17:47
Toaster? That's won me to the idea.
902771
