1998 Toyota Coaster
Submitted: Monday, Oct 28, 2019 at 18:14
Michael R1
Reply By: Frank P (NSW) - Monday, Oct 28, 2019 at 18:18
Wow, Michael, that's a bit cryptic.
What do you want to know?
Intervals?
How to?
OEM vs aftermarket products?
Etc.
A little more info will help immensely.
628372
Follow Up By: Michael R1 - Monday, Oct 28, 2019 at 18:22
I want to change the fuel filter on my 1998 Toyota Coaster it has 1HZ motor,
902722
Follow Up By: Frank P (NSW) - Monday, Oct 28, 2019 at 18:27
And what would you like to know about that?
902724
Follow Up By: Member - Boobook - Tuesday, Oct 29, 2019 at 08:44
Geez Frank. Why on earth would you expect Michael to invest more than 15 seconds explaining the issue when you can do all the work?
I think you are being a little unreasonable and should spend hours trying to guess what Michael wants so you don't waste his time while helping him. He is obviously very busy you know. Michael is very aware that his time is more valuable than yours. Get with the program.
These vague 3 - 4 word OP questions do amaze me.
902735
Reply By: Member - John - Monday, Oct 28, 2019 at 20:06
skip the first 20 seconds....
628375
Follow Up By: axle - Tuesday, Oct 29, 2019 at 12:38
That's Excellent
John, Not like the response from the other Boofheads!!
Cheers Axle
902754
Reply By: Member - Lyncol - Monday, Oct 28, 2019 at 23:24
Filter is under vehicle approximately inline with the side door undo sediment sensor clip can be a bit of a bugger remove filter with filter remover empty diesel out hold in vice and carefully undo white sensor, clean sensor and put new o ring on , comes with new filter , don’t over tighten sensor fill filter with diesel and screw back on:
628385
Reply By: OzzieCruiser - Tuesday, Oct 29, 2019 at 08:46
Read the handbook.
628390
Follow Up By: terryt - Tuesday, Oct 29, 2019 at 12:28
If you can tell me where to get a handbook for a 98 Coaster I would be very appreciative
902751
Follow Up By: OzzieCruiser - Tuesday, Oct 29, 2019 at 17:24
Its called Mr Google -
Here is a start
902769
Follow Up By: terryt - Tuesday, Oct 29, 2019 at 18:13
Thank you very much. I googled my heart out and didn't find that
902773
Follow Up By: Ron N - Thursday, Oct 31, 2019 at 21:54
What you find with a Google search, is very dependent on what Internet Browser you are using, and how your settings are set.
Chrome browser will find much better search results with Google than any other browser, and if your Internet setting are set to the highest levels of "safety", you have a lot of useful search results omitted.
Cheers, Ron.
902829
