Mitzabishi canter wiper problem
Submitted: Sunday, Oct 20, 2019 at 17:41
ThreadID: 139214 Views:4978 Replies:3 FollowUps:4
The wipers on my canter turn on & work all speeds but won't turn of can anyone suggest why
Reply By: Member - Neil T6 - Sunday, Oct 20, 2019 at 18:34
Normally caused by the cancelling mechanism in under the centre of the steering wheel.
AnswerID: 628230
Follow Up By: RMD - Sunday, Oct 20, 2019 at 19:51
Cancelling mechanism for wipers under the steering wheel?....
If the wipers won’t turn off, there is probably a fault in the parking disc on the wiper gear set OR they’re is a short in the parking wire and it is constantly earthing the motor instead of only having park current switched OFF by the springy copper wiper within the parking sector of the wiper motor. All is mounted under the flat plate of the wiper.
FollowupID: 902518
Follow Up By: Member - Neil T6 - Sunday, Oct 20, 2019 at 21:29
Sorry about that, I didn't read it properly and assumed it was indicators. Age catching up.
FollowupID: 902519
Follow Up By: RMD - Monday, Oct 21, 2019 at 08:19
Neil.
It did say "wiper problem in heading and first line of text. But it is apparently a "Mitzabishi", that could be the problem.
If it was a Mitsubishi it might be different wiper setup.
FollowupID: 902521
Follow Up By: Malcom M - Monday, Oct 21, 2019 at 09:02
Might be a BitsaShitty
FollowupID: 902522
Reply By: Member - Ross N (NSW) - Tuesday, Oct 22, 2019 at 16:57
I have the same problem on my Landcruiser 2017 Cab Chassis only the fault is
Intermittent and , of course, wouldn’t, do it at the two dealers I have taken it to.
Grrrrr
Ross
Ross N
AnswerID: 628268
Reply By: RMD - Tuesday, Oct 22, 2019 at 19:03
Most wiper motors have, I presume the Canter is same concept, 3 or 4 small screws on the rim of the gear enclosure. After the motor worm drive and linkage has worn a bit it causes the large gear to overrun it's original position slightly. That overrun allows the segment of park ring inside to be earthing to negative instead of stopping. Usually, if you loosen the small rim screws and turn the plate with the nylon fitting a few degrees in the direction of arm rotation it should then park as normal.
The motor shaft usually has a screw adjustment with a lock nut. Over time and useage there WILL be more end float than original. The screw rests against a small ballbearing in the end of the motor shaft. That screw, with locknut loosened, should be turn inward, clockwise thread, so to restore the minimal endfloat of the motor shaft. The adjusting screw should not be tightened against the motor shaft, just loose slightly. That stops the internals flapping around as it is turned off. DO that adjustment first then the circular plate rotation adjustment second. There could be other issues but the adjustment is a starting point.
PS mark the plate and body so you know where you started from.
AnswerID: 628269
