Saturday, Aug 03, 2019 at 05:01
If the bolts on the towbar are loose you will always get the same result on any vehicle. I think you forgot to mention one of your tow bars was a Hayman Reese aftermarket bar that again the bolts weren't tensioned correctly.
My 7year old PX1
Ranger has now done 115000K of towing 2.5t and loaded to between 2.9 and 3t. The 115000T is the towing figure, the vehicle is at 145200K and in that time I have not had one problem despite being told here the engine wouldn't last 100000K and the auto gearbox would break, that the diffs filler plugs were in the wrong place which is rubbish.
Friend just bought one with over 250000K on it for a good price and it runs
well. It has never had any modifications like the egr being blanked off.
When I change my diff and transfer oils, the oil comes out clean with no hint of any wear and the same goes for the auto box except fro a bit of colour change of the ATF. Engine oil is very clean when changed and even now when I refill I have trouble seeing their level on the dipstick.
Ford has had class actions against them and so have the Toyota motor company, which many seem to think are above the others, and class action means they won't, cant fix or hide a known problem.
900950
