Saturday, Jul 06, 2019 at 16:13
Some more thoughts for a trip from west-east
- if you cross the Gasgoyne River make sure you let your tyres down before you get into the sand - it's a long long long way across! There was a
rock(ish) based crossing a bit to the east (right). It was hot & dry when we went and the sand was super soft - we launched into it with road tyre pressures and promptly got bogged within 50m. If you're towing I'd recommend going for a bit of a walk first so you can work out which way to go and where some hard sand might be if you want to stop.
- there are some really nice spots along the western side at
the springs - we camped at Chafcutters Spring and it was one of the best campsites of our 10 week trip. There are some sculptures on the top of the
hill to the north - we wandered up to them. Climb the
hill to watch the sunset over the plain. I think Chafcutters was the nicest spot, especially up the back a bit.
- As you near the eastern side the road does a big loop south. You can stop and walk about 200m through the bush to the top of a huge canyon. Make sure you have a compass so you can find your way back to the track
- I'd advise picking a
campsite on the southern end of the cliffs - close to where you come out at the cliffs. We, unfortunately, went a bit "Goldilocks" on our site selection (nothing was quite right) and eventually came to the track heading down the range. We ended up camping on top of a smallish
cliff with surface rocks everywhere (yeah for the Tvan!). I wish we had stopped earlier...
- Your car will get scratched... the track is pretty narrow
- If you're the first one through for a while watch out for termite mounts on the road - some where "diff height" because everyone else had knocked the tops off them
- there is an old
homestead about 500m past the turnoff down the range. To the south of the
homestead there is an old dump with interesting bits in it. If you follow the water pipe up the
hill then down (below
the rock band) you'll find the
old well. Make sure you don't fall in.
900404
