Toyota Landcruiser V8 Utes, What Revs are they doing at 110kms hr ?
Submitted: Saturday, Jun 01, 2019 at 11:46
axle
Everytime one passes me on the hwy ,it sounds like they are doing around 6000rpms!....and that's listening to them from inside a defender!..lol.
For those that own them ,how noisy are they to drive on the Hwy?
Cheers Axle.
Reply By: Allan B (Sunshine Coast) - Saturday, Jun 01, 2019 at 12:09
Axle, that is just the wind noise as they approach Mach speed. lol
625904
Follow Up By: axle - Saturday, Jun 01, 2019 at 12:22
Huh?...…
Cheers Axle.
899539
Follow Up By: Allan B (Sunshine Coast) - Saturday, Jun 01, 2019 at 12:29
Well Axle, "Mach speed" is all about......... ah, forget it. What I meant was that they are going very much faster than yourself.
It was a joke Axle. Talk about lead balloons....!!!! lol
Now don't ask me to explain that one too Axle.
899542
Follow Up By: axle - Saturday, Jun 01, 2019 at 13:26
I'm ROTFLMAO!
Cheers.
899548
Follow Up By: OBJ - Saturday, Jun 01, 2019 at 19:50
Oh dear ....
OBJ
899564
Follow Up By: RMD - Sunday, Jun 02, 2019 at 10:32
Gee Allan. That is a bad typo, don't you mean Max speed? Mach speed is only a dream while cruising in sleep mode. At Mach speed the aluminium panels would tear off and a blinding meteor shower of rivets would be the result.
899573
Reply By: Ron N - Saturday, Jun 01, 2019 at 13:05
The Landcruiser V8 diesel utes were doing 2600 RPM at 110kmh, up until the MY2017 release, when Toyota revised the gearing in 5th gear (overdrive) to reduce the engine RPM to 2200 RPM at 110kmh.
Landcruiser utes have never been noted for quietness, and most of the owners of them, seem to like them making a lot of noise - particularly the V8 burble!
The reduced engine noise level has only accentuated the wind noise caused by the boxy cabin shape, the 1960's-shaped exterior mirrors, and the
snorkel.
The Landcruiser ute has suffered from a lot of design deficiencies since the introduction of the V8 diesel - and it's all to do with Toyota's incredible stupidity of "don't change any more in the design, than we absolutely have to".
There's a rumour the new 2019 model has been sighted with a widened rear axle - at long last! - plus a 6 speed transmission.
Now all Toyota have to do, is shift the position of the V8 starter motor (so it doesn't go rusty in a
pool of water in the V of
the block - and shift it so it doesn't entail removing the fuel injection plumbing to get it out!) - and shift the position of the alternator, so it doesn't fill with water after traversing deep puddles!
Cheers, Ron.
625905
Follow Up By: RMD - Saturday, Jun 01, 2019 at 13:15
Hang on a minute Ron, the mods for starter and axle and alt position can only be done after careful consideration of all factors and that may take years to go through the design process.
as long as you don't use the engine then the starter lasts quite
well. The rear Bulldog, wide front narrow rear, is nearly through that process of design change. They discovered it was like that when they revisited their design sheets a few years ago.
The alternator is self draining so not a problem.
899545
Follow Up By: axle - Saturday, Jun 01, 2019 at 13:25
Hi Ron, They might get it all together one day, it just amazes me the design deficiencies they have had from day one,...let alone the cost .
Goes to show when there's been no real competition in that sized ute ,what they have got away with.
Cheers Axle.
899547
Follow Up By: eaglefree - Saturday, Jun 01, 2019 at 17:22
Not many vehicles were/are made with the mechanic in mind. Aka early mini/Morris 1500 etc
899557
Follow Up By: Steve in Kakadu - Saturday, Jun 01, 2019 at 19:41
I have a brand new ute at work, 2 1/2 weeks old. Same diff and 5 gears, the only downfall is the 1 fuel tank.
899563
Reply By: Kenell - Saturday, Jun 01, 2019 at 13:16
Depending which gearbox they have, probably around 2300rpm. The newer ones run about 200rpm lower than those produced pre 2016 ish. The ones with the DPF tend to make a tinnier noise I reckon which might be mistaken for higher revs when mixed with wind and road noise etc. My 76 sits on exactly 2000rpm at 100kph in 5th. I have the new gearbox now. The old one was 2200rpm under the same conditions.
Kenell
625906
Follow Up By: axle - Saturday, Jun 01, 2019 at 13:31
That's not so bad then Kenell, .about the same as my 2wd Triton.
Cheers Axle.
899550
Follow Up By: RMD - Saturday, Jun 01, 2019 at 15:49
That makes it 2200 rpm at 110kmh.
899555
Reply By: Member - Boobook - Saturday, Jun 01, 2019 at 13:16
A new 70 will sit at around 2180 RPM at 110kmph.
How may RPM would the Defender theoretically be doing if it could get to 110?
625907
Follow Up By: Member - lyndon NT - Saturday, Jun 01, 2019 at 13:23
LOL, don't knock the defenders they were a great car.......... (when my Dad was in nappies)
899546
Follow Up By: Member - Boobook - Saturday, Jun 01, 2019 at 13:27
LOL I know how good they were. I had a Landrover 35 years ago.
I will never forget it...... Actually I can't forget it, because I'm reminded of it every time I look at the black stains still on the driveway.
899549
Follow Up By: axle - Saturday, Jun 01, 2019 at 13:40
AH!, ...Never a dull moment when you mention landrover!
BooBook in answer to your question, about 9,800 ……
Cheers Axle.
899551
Follow Up By: Member - Boobook - Saturday, Jun 01, 2019 at 13:56
Mission of the month accomplished then Axle.
899552
Follow Up By: RMD - Saturday, Jun 01, 2019 at 15:46
Weren't they called a 110 anyway? so they always cruised at 110!
899554
Reply By: RMD - Saturday, Jun 01, 2019 at 13:17
Axle,
All v8 engines at same revs have twice as many power pulses, firings, exhaust blurts as a 4 cyl does at same revs. Of course they sound busy, there is twice as much happening in the same time.
625908
Follow Up By: axle - Sunday, Jun 02, 2019 at 12:24
Really RMD,!!!.
Your Knowledge of Everything in this world is absolutely Astonishing!...(.NOT)
Cheers Axle.
899578
Follow Up By: RMD - Monday, Jun 03, 2019 at 13:13
Axle.
Didn't you want your question answered? Your ears may be out of frequency if they sound like 6000rpm. A V8 at 6000rpm has far higher sound than you are claiming.4 pulses x 6000 = 24000 or 4 times the frequency of 240vAC. quite fast. If 6000rpm the Toyota would be nearing 300kmh. Do they really pass you at near that speed? Speed and sound don't seem to match.
What is next months topic?
899613
Follow Up By: axle - Monday, Jun 03, 2019 at 14:02
RMD, You need to slow down, slow up ,lightenup, and not treat this
forum like you you own it!. There are others here that have good knowledge as
well if you will let them in.
Give me time, i'll think about the next topic!
Cheers till next time
Axle.
899614
Reply By: veight - Saturday, Jun 08, 2019 at 17:13
I have a 2014 79 series work ute,
at 110km rpm is 2680 at 130km 3150rpm according to my scanguage II.
626087
Follow Up By: axle - Sunday, Jun 09, 2019 at 20:30
That's more like it mate.
899778
