Victron BMV-712 UTP cable
Submitted: Wednesday, May 29, 2019 at 09:10
116hynes
Can anyone tell me if the UTP cable on the Victron BMV-712 is a standard RJ45 cat6 cable?
Thanks, Kevin
Reply By: Member - Racey - Wednesday, May 29, 2019 at 09:34
Kevin, it's an RJ12.
625842
Follow Up By: 116hynes - Wednesday, May 29, 2019 at 09:37
Thanks Racey, so any RJ12 cable will do?
899453
Reply By: Member - Racey - Wednesday, May 29, 2019 at 17:38
Kevin, I believe so but not 100% sure.
625851
Reply By: Sand Man (SA) - Thursday, May 30, 2019 at 07:29
As Racey has identified, any standard RJ12 patch lead will work. RJ12 has 6 pins connected.
RJ45 has 8 and RJ11 has 4.
Just be aware that some retailers don't know what a standard RJ12 cable is.
I purchased one and had to return it as it was a "cross-over" cable.
Just
check that the pins have the same colour wire connected to the corresponding pin at each end.
i.e. a straight through cable, pin1 to pin1, etc.
625858
