200 series VX rim options.
Submitted: Tuesday, May 28, 2019 at 12:55
ThreadID: 138407 Views:5978 Replies:3 FollowUps:2
can anyone tell me whether you can fit the normal Toyota GXL 17” rim to the rear of a 200 series VX model which is currently fitted with a 18” rim. The pitch circle diameters on the studs are the same on both rims.
I understand a 17” won’t fit the front because it fouls with the calliper but are uncertain whether this problem exists on the rear wheels. Also if it is a problem is it the offset or inner diameter of the rim.
I only propose it as an emergency situation.
Cheers Craig
Reply By: Rob A2 - Tuesday, May 28, 2019 at 14:00
A quote directly from the LCOOL thread. 17" wheels will not clear the larger brakes/callipers that came out with MY16 and onwards.
So it depends on what year VX you have
Evidently there are aftermarket rims you can purchase from ROH
Rob
Rob Ackland
AnswerID: 625816
Follow Up By: Craig M1 - Tuesday, May 28, 2019 at 19:47
Thanks Ron
Cheers Craig
FollowupID: 899444
Reply By: CSeaJay - Tuesday, May 28, 2019 at 14:30
You cannot fit a 17 inch from other 200 models on the VX from MY15 onwards as it does not clear the larger brakes that come with this model.
AnswerID: 625817
Follow Up By: Craig M1 - Tuesday, May 28, 2019 at 19:49
Thanks CSeaJay
FollowupID: 899445
Reply By: Member - Boobook - Tuesday, May 28, 2019 at 16:29
It will fit all pre 2015 wheels and the rear in a 2015 plus rear wheel. Offset and pcd are the same.
Another option is the roh octagon 17". It has a 48mm offset and will fit the front or rear.
AnswerID: 625819
