Anne Beadell flexible permits?
Submitted: Thursday, May 09, 2019 at 06:50
ThreadID: 138300 Views:5271 Replies:4 FollowUps:2
The permit forms require the exact date planned to cross the areas. Chances are that you may be a couple of days late or early. Does anyone know how that problem can be solved?
Limablu
Reply By: cookie1 - Thursday, May 09, 2019 at 07:34
Personally I wouldn't stress too much about it so long as you have permits and within cooee of your travel dates I think the rangers would be OK, it is the intent of doing the right thing but not everything can go to plan.
I think they would sooner catch those without permits doing the wrong thing with no intent of being upfront & honest.
AnswerID: 625443
Follow Up By: Siringo - Thursday, May 09, 2019 at 11:39
Totally agree with cookie1.
On the WA Planning Lands & Heritage site it says approximate dates from memory.
Also what are the chances you're going to bump into someone who requests to see your permits, I know it happens, but it must occur very rarely.
I'm going through this process right now as well and I believe that if I have a permit and I'm a few days out and I get asked for the permits, I'm not going to stress as it can be seen that I've done the correct thing.
FollowupID: 899133
Reply By: Member - Boobook - Thursday, May 09, 2019 at 07:44
Make the start date the earliest you think, and the end date the latest.
AnswerID: 625444
Follow Up By: Shaker - Thursday, May 09, 2019 at 08:09
Allowing for possible weather, health, accident or mechanical issues!
I have always thought the date in - date out requirement to be ridiculous, Outback travel is far from an exact science.
FollowupID: 899124
Reply By: Member - Markus B (INT) - Thursday, May 09, 2019 at 15:34
So appreciate your instant feedbacks thank you. We're swiss travellers and a little unsure of how stringent such laws are. Also glad to see that you Aussie travellers also wish there was more flexibility in order to accomodate the fact that travelling shouldideally not be kept to rigid timetables if at all possible.
AnswerID: 625450
Reply By: Member - RobnJane(VIC) - Thursday, May 09, 2019 at 18:15
Hi Markus,
The replies noted cover the topic well, however it is good to be aware that one of the permits you will need is from The Department of Defence for Woomera, a test facility. It can occur during the application process the people on the ground in Woomera will contact you to confirm actual dates of entering and leaving their zone. This has happened to us twice now.
Hasn’t been a drama but you do need to consider your travel dates and be prepared with alternatives.
Hope this info is useful.
Rgds,
Rob
RobnJane
AnswerID: 625454
