Hema 7 Track file names
Submitted: Tuesday, May 07, 2019 at 13:29
Trevor
Greetings
I have two Hema 7s bought about 18 months apart and their serial numbers are several hundred apart.
Both have started to produce 2 files for tracks.
This annoyance started around the 24th of April. The two files have different names, one has the correct date and the other has a date in 2099.
In April the incorrect date was some time in June 2099.
This happens on both daily and monthly files.
The data stored is correct in both files.
I have had some email conversations with the Hema organisation but they have been a little less than helpful.
Has any body else come across this problem?
Trevor
Reply By: Frank P (NSW) - Tuesday, May 07, 2019 at 13:44
Reply By: Trevor - Tuesday, May 07, 2019 at 13:48
That was my thought but Hema responded with -
The 10 bit time/date software system (GPS update) does not apply to the Hema Navigators HN5, HN6, HN7 or HX-1.
Trevor
625416
Reply By: The Explorer - Tuesday, May 07, 2019 at 14:10
Hello
You may wish to contact Des at OziExplorer and explain your issue (assuming that is the software in use)
625418
Reply By: RMD - Tuesday, May 07, 2019 at 17:57
Trevor.
While keeping a record of tracks or waypoints, have you done a factory reset on at least one device to see if it reboots with it's brain not seeing Double?
625421
Follow Up By: Trevor - Tuesday, May 07, 2019 at 23:02
On Hema's advice I did a an Ozi 'Reset All Settings' through the Ozi Settings page.
It didn't fix the problem.
T.
899106
Follow Up By: RMD - Wednesday, May 08, 2019 at 11:40
Trevor,
That OZI reset all is probably for the OZI settings and isn't for the HEMA device reset. I would imagine they are two different entities.
899111
