Monday, May 06, 2019 at 10:43
A shortened drawbar length only exacerbates sway and makes reversing more difficult.
All vans should have shock absorbers fitted as standard - for exactly the same reason as cars and trucks do.
In fact, vans have a higher requirement for shock absorbers, because of their body height, which also exacerbates sway.
But the greatest single factor that creates van sway is simply the amount of overhang behind the axle or axles - and where the weight is positioned in the van.
Well-designed vans and trailers do not have excessive overhang, and they do not have their axles positioned centrally, they have them positioned at least 50mm, and more often, 100mm behind the centreline of the main body section.
Good-handling vans also do not have any heavy items mounted or stowed behind the axles.
Cheers, Ron.
899045
