Monday, May 06, 2019 at 14:32
Has it been previously been operating O.K., or has the problem started as soon as you hooked them up?
Being a BMW, we're entering minefield territory, with BMW engineering and electronics being horrendously complex, and needing specific BMW service
tools to do repair work.
A friend with a BMW has found you can't use an off-the-shelf OBD-II code reader in a BMW, you need the BMW code reading scanner, it is specific to BMW.
Then again, being a new van, the problem may simply be faulty assembly work on the part of the van builder, and it could be something as simple as incorrect wiring, a faulty earth connection, or even just loose wires.
Cheers, Ron.
899057
