CARAVAN LIGHTS ON CARS WITH REVERSING SENSORS
Submitted: Sunday, May 05, 2019 at 14:50
ThreadID: 138276 Views:7160 Replies:8 FollowUps:20
Has any one had problems with park lights flashing on caravan with cars with sensors ?12 PIN PLUG.
Reply By: RMD - Sunday, May 05, 2019 at 16:51
Hello David.
Can you describe what is happening and when please. Even though it has reverse sensors it may not be connected with the issue you are experiencing.
AnswerID: 625379
Reply By: IvanTheTerrible - Sunday, May 05, 2019 at 19:06
Probably a Ford Ranger or a European car and the van lights will be LED. If so you will have to get resistors fitted to the vans park lights.
AnswerID: 625381
Follow Up By: RMD - Sunday, May 05, 2019 at 19:50
Why. What do resistors do to cause flashing?
FollowupID: 899028
Follow Up By: IvanTheTerrible - Sunday, May 05, 2019 at 20:31
You fit resistors to stop the flashing
Some vehicles pulse the line to see if there is a trailer connected. With a filament globe there isn't enough power in the pulse to light the filament but LED's dont present enough of a load thus the light. Ford released an adaptor to correct this and charged $150 for it and all it was was a plug, a socket and a couple of 17 cent resistors.
FollowupID: 899031
Follow Up By: Ron N - Monday, May 06, 2019 at 00:21
Ivan - 17 cent resistors?? Where do you get LED resistors for that price?
When I fitted LED tail lights to my Hilux, my local automotive parts supplier charged me $11.00 each for Narva resistors for the indicators!
I reckoned it was a total rort, but I still haven't found any, for anywhere near 17 cents each.
But after looking at this following eBay pricing, it looks like I got a good deal!
eBay - Narva LED resistors
Cheers, Ron,
FollowupID: 899035
Follow Up By: Michael H9 - Monday, May 06, 2019 at 05:35
When I bought the Ford adapter it cost me $25. The problem is definitely LED lights and the car being Euro style where the car wants to know if anything is being towed.
FollowupID: 899036
Follow Up By: Member - Boobook - Monday, May 06, 2019 at 07:39
Not quite 27 cents, but $11 for a pack of 10 Here for example
the stop and indicator should be the next ohm size up from 6 ohms, the tail should be next size up from 20 ohms.
The tail should be 10Watt and the others 20W.
I am sure you can get away with higher value resistors, They could be lower wattage, and could well be as low as 17 cents if you know what you are doing.
Go to Jaycar and the price will be a lot less than Narva.
FollowupID: 899037
Follow Up By: RMD - Monday, May 06, 2019 at 08:48
Why don't the vehicle lights flash if the line is being pulsed? What lights does it have LED or Globes?
Many towbar systems have Relays OR Solid State switching to detect an input from the vehicle loom and switch current from a dedicated +ve feed to the appropriate relay and then to the wire in the trailer plug.
Dmax have similar to cater for additional loads on trailer flashers. I lamp or 10 per side doesn't make any difference.
David hasn't mentioned what type of lights he has on his vehicle or van, yet.
FollowupID: 899041
Follow Up By: 9900Eagle - Monday, May 06, 2019 at 09:26
I use these on the van and they have been there for 7 years with no problems. I also carry a Ford adaptor for other trailers I might hook up to. It was genuine and less than $20 when I bought it. 24 cents a resistor.
The resistors are in an adaptable Box with poly glands on the A-Frame, I mounted it so no stones can cause a problem, and it is easy to get too and easy to change the lead and plug if required.
Jaycar resistors to suit
FollowupID: 899042
Follow Up By: IvanTheTerrible - Monday, May 06, 2019 at 19:05
Follow Up By: IvanTheTerrible - Monday, May 06, 2019 at 19:08
RMD It's a trailer module that does it not a relay. Thats why I assumed it was a Ranger or a European car as the use modules. I'm not guessing at this. I do this for a living
FollowupID: 899073
Follow Up By: nickb - Tuesday, May 07, 2019 at 19:39
I tried a few resistors on my 2014 Ranger, the highest resistance I could use was 22ohm (10W) otherwise the indicators would flash slow/fast at random intervals.
https://www.jaycar.com.au/22-ohm-10-watt-wire-wound-resistor/p/RR3356
FollowupID: 899102
Follow Up By: IvanTheTerrible - Tuesday, May 07, 2019 at 19:43
nickb This is on the trailer not the vehicle.
FollowupID: 899103
Follow Up By: nickb - Tuesday, May 07, 2019 at 21:46
Ah ok. From memory my trailer ones are around 100ohm, similar if not the same as the ones in link.
FollowupID: 899105
Follow Up By: IvanTheTerrible - Wednesday, May 08, 2019 at 17:37
I was lucky. When Ford first had this issue the local SES brought a vehicle in with the adaptor so I opened it to see what resistors were in it. :-)
FollowupID: 899117
Follow Up By: Allan B (Sunshine Coast) - Wednesday, May 08, 2019 at 18:29
Good one Ivan.
FollowupID: 899121
Reply By: Member - David G (VIC) - Monday, May 06, 2019 at 08:56
My car has filament globes and so dose the van , they are both about the same age 2003.
AnswerID: 625386
Follow Up By: Ron N - Monday, May 06, 2019 at 10:09
David, you still haven't explained the precise circumstances that causes the van park lights to flash?
Is it happening all the time the lights are on, or just when you brake, or some other specific circumstances?
In addition, what sensors are you referring to?
Cheers, Ron.
FollowupID: 899043
Reply By: Member - David G (VIC) - Monday, May 06, 2019 at 10:48
It only occurs on the park lights on the van.All lights on the car and van are filament globes.
I have 2 cars , and this only happens on the bmw , not the nissan patrol
AnswerID: 625390
Follow Up By: RMD - Monday, May 06, 2019 at 11:44
David G
I am still trying to work out the relevance of the reversing sensors in this. It might happen only on the BMW but WHEN is it happening?
When park lights are activated on the vehicle or when they are switched off.
Have you checked the wiring in the 12 pin base AND the trailer plug too for correct pin assignment of everything for each wire colour? Made sure there are no stray wire strands between component pins too?
If the vehicle is CANBUS ( almost certain it is) and it can't take the load of the trailer globes it may turn them on and off to save the ECU circuitry. Therefore, you may need a piggy back switching device, ie power fed relay system to remove the load from the vehicle and give the supply demand to the dedicated power feed from battery. Each relay turns ON as required for trailer lamp functions.
You didn't mention if this situation had recently started or you have for the first time connected the van to the car. This creates a few unknowns for people trying to remotely diagnose and provide a possible solution.
FollowupID: 899052
Reply By: Member - David G (VIC) - Monday, May 06, 2019 at 13:36
This is a totally new car and van , and its the 1st time it has occurred.
AnswerID: 625395
Follow Up By: Ron N - Monday, May 06, 2019 at 14:32
Has it been previously been operating O.K., or has the problem started as soon as you hooked them up?
Being a BMW, we're entering minefield territory, with BMW engineering and electronics being horrendously complex, and needing specific BMW service tools to do repair work.
A friend with a BMW has found you can't use an off-the-shelf OBD-II code reader in a BMW, you need the BMW code reading scanner, it is specific to BMW.
Then again, being a new van, the problem may simply be faulty assembly work on the part of the van builder, and it could be something as simple as incorrect wiring, a faulty earth connection, or even just loose wires.
Cheers, Ron.
FollowupID: 899057
Follow Up By: RMD - Monday, May 06, 2019 at 16:00
David.
Maybe take all but 1 globe of park globes out of van, ie. Just leave a side market globe which is low wattage and see if the pulsing stops and continuous illumination occurs. If it does it would indicate the overload of CANBUS system and an auxiliary switching device is needed to over come the situation.
FollowupID: 899063
Reply By: Member - David G (VIC) - Monday, May 06, 2019 at 17:55
Ok i will try your sugestion.Where do i get the required device from?
AnswerID: 625401
Follow Up By: RMD - Monday, May 06, 2019 at 18:15
David
Mazda seem to use one for towbars on CX3 . See the post a few down the page. 3 replies. Not sure for a BMW though.
FollowupID: 899069
Follow Up By: Ron N - Monday, May 06, 2019 at 19:25
David, you can buy one of these devices locally, for a sizeable sum ....
Redarc - Advanced Trailer Lighting Interface
Or - you can purchase one of these from the U.K., off eBay, and save a heap of money, because it will do the same job as the Redarc device.
eBay - Ryder Smart Logic 7-wire Bypass Relay for towing
An explanation of how the device works, and fitting instructions for the unit -
7-Way Smart Logic Module
Cheers, Ron.
FollowupID: 899075
Reply By: Member - David G (VIC) - Monday, May 06, 2019 at 20:10
Thank you very much for your imput.
David.
AnswerID: 625405
Reply By: Member - David G (VIC) - Monday, May 06, 2019 at 20:21
Thanks i have just bought this unit .
I will keep you up todate with the progress.David.
AnswerID: 625406
