Tuesday, Apr 23, 2019 at 15:26
Possibly, but not necessarily. Freezer should be set to -18 according to food standards, but you can get away with -12. If I understand your fridge/freezer set up, it is a combination unit but with only one compressor supplying both the freezer & the fridge, with the freezer supplying the “cold” for the fridge. It all depends on how many times you open the fridge as to how hard the unit has to work
Some people suggest to turn your fridge off when you go to bed, as if it is
well insulted, it will stay cold enough overnight, and then turn it on again first thing in the morning. I do not do this, as I am not convinced this is efficient, as the fridge will not “run” very much overnight anyway, and perhaps have to run harder in the morning when you turn it back on.
When we do not take the van, we use a 60 Ltr Engel as a fridge, & and a 35 Ltr Waeco as a freezer in the car. The car has 130 Ahr deep cycle battery, and the two folding panels I mentioned earlier. This allows us a good two or three days in the one location without having to start the car providing there is sufficient sun.
898730
