Wednesday, Jun 16, 2004 at 13:28
Hi, I couldn't help but post a response and offer an opinion.
Do your self a favour, unless you need to store a lot of food to feed a family of 10, just go with one 40litre Engel, forget the solar panels (unless you have a fair bit of cash spare to set it up
well), use the money you save on the second Engel to buy yourself a generator. Get one of those small lighweight portable 4 strokes, they are unbelievably quiet, you won't hear it running as they are so good in this regard. You can freeze water and transfer to an esky to keep your fruit and veges cool, (as suggested by other respondee) plus you have power to run lights, fans, heaters, laptop computer, powertools etc or even the TV!
I have a bushman fridge and did the same on my trip around Australia, as I found that up north in the tropics, coming into summer, it was so
dam hot that current draw on my fridge was excessive and although I figured at full power consumption of 4.5 amps from the fridge off my 100 amp deep cycle auxillary battery, I would get at least 20hrs at a go (30-40hrs when set as a fridge), this was not the case (generally the battery would last a day before discharging when set as a freezer).
But
Darwin and NW WA is hot,
dam hot, in November ..........
I recommend based on my experience, that you fork out the extra money for a good quality generator, with a pure sine wave inverter (about $1000 bucks or a tad more and roughly about the same price as another engel or solar panels with enough grunt to do the job).
I bought an el cheapo 650 watt 2 stroke for about $200 and cursed every day. I had to run 20m of extension lead so I could place the generator away from the
camp, to reduce niose, I had to run it 24/7 as it couldn't cope with directly charging any battery over 50amps and I had to moderate it with my battery charger via my deep cycle battery, to remove power surges which prevented me from running my fridge directly of it, or more sensitive electronic equipment.
Probably didn't do my deep cycle battery much good in this regard either.
Anyway.....
This wouldn't happen with a good quality 4 stroke generator whith sufficient capacity and a proper inverter.
DO NOT be persuaded by the Missus (like I was) to buy one of those stupid little cooler boxes in lieu of another engel to keep drinks cool, as they suck power like no tommorrow, and work poorly in any case (a waste of $100), stick with the Engel, ice and a decent esky.
Note that in some Nat Parks, they prohibit the use of generators - or have designated times for using them, but even still, you can generally sort something out, particulary if you have a 4 stroke that are so quite no one can hear in any case. ( I saw others using them on my travels and always went green with envy!)
Admittedly it would be nice to have solar panels with enough grunt, coupled with a good quality inverter, to do all that a generator can and save on fue, but hey, I made some enquiries along these lines and by god, it was not for the budget orientated, plus if your as clumsy as me, a size 9 1/2 foot accidently through a solar panel would not be fun.
Hope this helps you further consider the pro's and cons of various power options.
63422
