Help with phone aerial
Submitted: Friday, Mar 22, 2019 at 09:10
ThreadID: 138003 Views:2672 Replies:1 FollowUps:0
I believe this is a phone aerial of some sort. Can anyone tell me what make it is and what I need to make it usable. My phone has no aerial port.
I might have called both bits receivers
Reply By: PeterInSa - Friday, Mar 22, 2019 at 10:35
The 3rd lowest photo is same as my phone aerial, middle photo is thru the glass pickup, same as, at the end of the cable I have a plug that I attach another small cable to plug into my Blue Tick phone.
I suggest the top photo is for phones that don't have a plug and it either radiates the signal to a phone that does not have a plug, or another fitting plugs into this that allows you to put your phone inside it, like say a cup with embedded wire loop to concentrate the signal.
Suggest you check the number of bars on your phone ( in a weak signal area), then put your phone near the device in the top photo to see if there is an increase in the number of signal bars.
Alternatively if no answer here, send your photo to a CB/Phone shop ( eg Electric Bug in Adelaide)for identification.
AnswerID: 624551
