Blog Comment: User Treks: Instructions
Submitted: Sunday, Mar 17, 2019 at 02:07
Member - SDKD
Can I download a User Trek and use it on my ExplorOz Traveler App ? If so - how??
Reply By: ExplorOz Team - Michelle - Monday, Mar 18, 2019 at 13:34
User
Treks are are not compatible with the app. They don't have any routing, or waypoints so are not of much use in the app. You can create your own
treks in the app using the instructions to create a Private Trek, or you can select any of the pre-built ExplorOz
Treks to use as is, or edit to customise to your route. There are 187
Treks in the app to choose from.
User
Treks are more used for historical reference of where one has been and used to display on a map. You do this for yourself or to show others where you've been. It's nice to look at other people's User
Treks also for inspiration and whilst they can be downloaded to use in some other software (eg. OziExplorer) they don't give you the waypoints, just a route line on a map so you'ld need to rebuild the route if you wanted to navigate along it anyway no matter what program you used. Hope this clarifies.
624479
Reply By: Member - wicket - Tuesday, Mar 19, 2019 at 09:55
Michelle
I for one would be happy to have “just a route line on a map” if i could download some of the user
treks to the app, the other stuff (waypoints, navigation) can be superfluous at times.
624491
Follow Up By: Frank P (NSW) - Tuesday, Mar 19, 2019 at 10:05
I, too, would be happy to have the ability to import just a route line from a User Trek into Traveller. Just as you can import one into OziExplorer.
897997
Follow Up By: ExplorOz Team - Michelle - Tuesday, Mar 19, 2019 at 20:08
Sorry I posted my reply in the wrong spot, but the message is; I can turn any User Trek on as an ExplorOz Trek and then you've got it in the app - just talk to me and we can make it happen
898002
