Tuesday, Mar 12, 2019 at 23:47
Hi mepvic,
Recently, I bought a Samsung Tab A 10.1" T585 (Androud 6.0) from Kogan specifically for dash-mounting in vehicle with Tallon suction cup and frame, for use with
Exploroz Traveller (Android version). Downloading the app was easy, maps literally took hours and many resets to load -- effect of huge files and lousy ADSL internet speed at
home. The setup and private
treks are now locked and loaded, ready to go, so far only trial runs around
Brisbane but all good, Ali g the
Darling River Run in May (if the river still exists!), then parts West.
I do find the Samsung tablet touchscreen fiddly to use -- so much so that I prefer to do all planning activities on a WIN10 x64 bit Microsoft Surface laptop at
home even though this required purchase of an additional Windows licence for
Exploroz Traveller -- plus the agony of downloading the maps again (but no additional map cost). I can then save Places/Waypoints,
Treks etc on the Exploroz server then access and download them onto any licenced device, including the Samsung Android tablet. I had thought I would use the detachable Surface screen in the vehicle -- buuuut unlike a Samsung tablet, Surface has no internally installed GPS and so another gizmo would be required!
So much for the background.
I have experienced difficulty setting or opening
Places or waypoints by touching them on my Samsung tablet screen. Some days are worse than others and it is worst on dry hot days. Sounds a bit primitive but I have found that a moist or licked fingertip works better than a dry finger so I suppose this indicates an improved capacitive effect?
I have looked in all the Settings on my Samsung tablet and I have yet to find any means of improving screen touch sensitivity. Sometimes the tablet requires a little time to respond after touching the screen. Occasionally I have noticed a similar reluctance on some applications (not
Exploroz Traveller) on my Sansung S7 phone which also has no arrangement to vary screen sensitivity.
More internet research is required but my suspicions lie with the Samsung screen rather than the app.
One frustration I would note is that as I zoom in for close-up maps, the text in the labels of place names and road names actually reduce in size and are hard to read in a moving vehicle.
Comments from Michelle on all if the above would be welcome.
So there's a shared experience but I am not sure that it provides much help on your original question!
All that said,
Exploroz Traveller is very, very useful -- strongly recommended.
Go wel!
IndroCruiser
| 2006 Toyota HDJ100 Landcruiser Sahara 4.2 T/D - AHC/TEMS, BFG A/T 275/65R17, ARB Deluxe Bar, Kaymar Single Wheel Carrier, ARB Intensity lights Member My Profile Send Message |
624395
Follow Up By: mepvic - Wednesday, Mar 13, 2019 at 21:04
Thanks for your thoughts. As I just replied to Frank, another member, I just booted it up. Same problem right from the beginning. Opened up Google maps and have no problem opening up local businesses or
places with either my finger or with the pen. Need some advice from Michelle and David on whether there is anything in the program that defines the area to be touched on the screen.
897894
Follow Up By: Member - IndroCruiser - Wednesday, Mar 13, 2019 at 23:59
Conversely, tonight I am having less trouble opening
Places on my Samsung tablet than I was a few nights ago. It all seems pretty good at the moment but I cannot explain the variability in performance. This is no help to you -- agree that it is time to call in Michelle and David ....
897897
Follow Up By: Member - IndroCruiser - Thursday, Mar 14, 2019 at 00:45
I have just found the information at the link below and have been playing with “pointer speed”. This does seem to improve touch sensitivity in my case – may be worth a try on your tablet …..
• Tap settings.
• Tap Language and Input.
• Scroll to the very bottom of these settings and tap pointer speed.
• Increase the slider to make the touch screen more sensitive and easier to tab.
• Decrease the slider to make your touch screen less sensitive and more difficult to tap.
• Tap OK and then experiment with the results.
Android Screen Sensitivity | 2006 Toyota HDJ100 Landcruiser Sahara 4.2 T/D - AHC/TEMS, BFG A/T 275/65R17, ARB Deluxe Bar, Kaymar Single Wheel Carrier, ARB Intensity lights Member My Profile Send Message |
897898
Follow Up By: Frank P (NSW) - Thursday, Mar 14, 2019 at 08:54
Thanks IndoCruiser. I hadn't found that setting. . But having played with it on my two devices, I have to report that sadly it makes no difference.
897900
Follow Up By: ExplorOz Team - Michelle - Friday, Mar 15, 2019 at 12:53
Hi Indrocruiser, sorry I did not notice this discussion until now where you've directly invited me to comment. All I can actually say is this is the first discussion ever on the issue I've come across so David has not been involved with any investigations on this so there's not much we can say at this point as we haven't seen it happen. Since the last update was quite a while ago now (5th February, almost 6 weeks ago now ) it seems unlikely this is being experienced by all users so I feel this is either related to the device touchscreen or settings as you've said. Best to do some Googling on fixes for that...
There is also the chance it is operator issue - another user contacted me the other day about something about not being able to open
places he was using too long a press on the place button and a lighter tap was all that was required.
Sorry I'm not much help am I ....
897925
