95 or 98 fuel
Submitted: Saturday, Mar 02, 2019 at 17:33
ThreadID: 137885 Views:5193 Replies:9 FollowUps:8
95 or 98 fuel for 4500
Reply By: Member - Rob S (NSW) - Saturday, Mar 02, 2019 at 17:52
Unless its been tuned to run on 95 or 98, just run it on std 91 ulp?
fuel guide
fuel guide
I only ever made one mistake
AnswerID: 624143
Reply By: Erad - Saturday, Mar 02, 2019 at 19:31
Several things about E10 vs 91 RON petrol.
1 The energy content of E10 is less than unleaded petrol, so to get the same amount of power out of the engine you will need more of it. I have run tests on my wife's Mitsubishi Outlander, and I have found that I need about 10% more E10 to cover the same distance as if it was using 91 unleaded.
2 The RON rating is a measure of the anti-knock properties of the fuel. Whilst E10 may have a higher RON number, if your car will run OK on 91, you don't need any higher RON, so E10 offers no real advantage.
3 The altitude you are running at makes a big difference to the RON level of petrol required to prevent detonation or pinging. The higher the altitude, the lower the RON needed.
4 Some engines have a detonation (or knock) sensor built into the engine control. This allows the ignition to be advanced more with a higher RON fuel. The greater the ignition advance, the better the power delivery. Or rather, you can use a lower RON fuel but you will get slightly less power from the engine. I have tried running my wife's Outlander on 98 RON fuel and because it has a knock sensor, it did use less fuel for the same distance travelled. However, the extra cost of the fuel was not offset by the extra economy, and 91 RON fuel is still the most economical for us.
If your engine does not have a knock sensor, there is no point in using a higher RON fuel than specified unless you advance the ignition to take advantage of the better fuel. In modern engines, the ignition advance is set by the ECU, and rarely can you alter it.
I keep records of everything which goes into the car - oil, tyres petrol, filters etc and by far the largest cost associated with running a car is depreciation. Petrol comes in a long second.
The biggest factor influencing the fuel consumption is the deriving style. If you drive the car 5 km to the shops and back, the fuel consumption will be 50% or more higher than if you get the car warmed up and drive out on the highway at the normal highway speeds. Excessive acceleration or high speeds will chew up more fuel that anything else. My wife's car is used as a shopping cart during the week, so fuel consumption is awful, but regularly it gets used to drive 120 km trips (minimum) and you are then comparing maybe a week's usage of short trips - say 25 km - to 120 km of nearly ideal operating conditions. Our cars get much better operating conditions than most city cars.
As an example, some time back, I drove my car (a Pajero diesel, towing my caravan down) to Sydney. Highway speeds all the way, it used 11.1 L/100 km. Excellent, considering the caravan has the aerodynamics of a brick. My wife got sick and was in hospital for 10 days in Sydney. travelling each day from where we were parked to the hospital, I covered about 350 km, but used 13.3 L/100 km, and that was WITHOUT the caravan. Lovely thick city traffic. We were glad to be out of the place. Driving a petrol car in heavy city traffic will completely negate and fuel savings you can achieve by using different grades of petrol.
I am not sure if the Toyota engine has a knock sensor (from memory ti doesn't), but if it doesn't there is little value in going to the dearer fuel.
AnswerID: 624145
Reply By: Ron N - Saturday, Mar 02, 2019 at 19:51
Philip L4 - What make of engine (there's more than one make of 4500cc size engine), and why do you ask?
Are you experiencing engine pinging, are you looking for more power, are you looking for more economy, or are you just curious about the economics of using either grade of fuel?
Cheers, Ron.
AnswerID: 624147
Follow Up By: Tony W - Sunday, Mar 03, 2019 at 01:03
Yes, it's recommended to use 46 to 52 cetane in my 4500.
FollowupID: 897556
Reply By: Shaker - Saturday, Mar 02, 2019 at 20:10
What does the owners manual say?
AnswerID: 624148
Follow Up By: Tony W - Sunday, Mar 03, 2019 at 01:05
Why waste 2 minutes reading the owner's manual when you can spend 10 seconds posting a question, getting dozons of others to waste hours.
FollowupID: 897557
Reply By: Member - McLaren3030 - Saturday, Mar 02, 2019 at 20:43
Sorry Phillip L4, you need to be less cryptic with your question. What vehicle are you referring to, how old, etc. Most modern European high performance petrol engines are designed to run on 95 RON.
AnswerID: 624149
Reply By: mechpete - Saturday, Mar 02, 2019 at 20:55
England an europe only have have 95 fuel
They don.t have 91
Mechpete
AnswerID: 624150
Reply By: RMD - Saturday, Mar 02, 2019 at 23:55
I used to frequently drive from central Vic to Adelaide/return. I first tried 98 in a 2008 2.2L Camry which used 10 litres less in 609 km, repeated many times, than lower octane fuel would deliver. 55L down to 45L used for 609km.
Changed to 1.8 Corolla and tried the same thing on exactly the same route both ways. First a few times with 95 and then with 98. The Corolla used less but not as much difference.
The Camry at the time returned a total money saving of about $4 even though the fuel cost more initially. Corolla only a small saving of close to $2.
Haven't tried it in a large petrol multivalve, but it may make a difference and cost less overall. Only your driving style and state of tune can ensure anything positive though.
AnswerID: 624156
Reply By: Alloy c/t - Sunday, Mar 03, 2019 at 10:24
$$$$ or Milage / Km should be the 'real' question ....My 4lt v6 by the 'book' is 95 ron or E10 is as well suitable , but here's the real thing , 159lt tank [ 014 Fj Cruiser ] low fuel light activates when 19lt left in tank ......91 ron consistent get 1,350km for 140 lt , when I use 95 ron get 1,390 for 140 lt and when have used 98 ron get 1,400 km for 140 lt .... there it is , no ifs , no buts ....price difference from 91 to 95 [on average out our way ] means to use 98 costs $30 more to do an extra 40km and an 'extra' $50 to do 50km more on 98 compared to 91 .... thats a lot of $$$$ over the 'life' of a vehicles ownership ....
AnswerID: 624157
Follow Up By: Member - shane r1 - Sunday, Mar 03, 2019 at 17:11
Hi Alloy
So I don’t have to do the sums,
does that come out that the higher octanes are costing you more per Klm?
FollowupID: 897568
Follow Up By: Alloy c/t - Monday, Mar 04, 2019 at 10:14
Shane r1 , the maths is not hard , if I use 98ron I'm paying an Extra $50 to get an extra 50 km over and above 91ron ...is it 'worth it' ?? IMO no , yes there may be a very very slight 'power' difference BUT the only way to prove that would be on a dyno in very controlled conditions ....just about every vehicle sold now uses an ECU which over a tank or 2 will self adjust to the RON rating to give 'maximum' performance from the fuel the engine is fed ......
FollowupID: 897591
Follow Up By: Member - shane r1 - Monday, Mar 04, 2019 at 14:52
The maths isn’t too hard , but you’re just stating $50 for the extra 50 Klm not what the whole tank costs or cost per Klm.
The sums on the extras $50 for 50 Klm is very bad economy @ $1 per kilometre. ( I could see it wasn’t adding up to being cost effective just the explanation isn’t very clear, sorry)
FollowupID: 897604
Follow Up By: Craig H4 - Monday, Mar 04, 2019 at 23:41
Hi Alloy, Just wondering when you did your tests did you fill 2 or 3 tanks of the same ron consecutivly so the ECU had a chance to adjust and if so did you see any difference in milage between tank 1 and say tank 3 or 4 on the same ron fuel?
FollowupID: 897645
Follow Up By: Alloy c/t - Tuesday, Mar 05, 2019 at 11:21
Yes Craig H4 , not extremely scientific , But 4-5,000 odd km on each type of fuel so the ECU 'learns' ...and of course driving style variations , load , wind , mountains , flat land , etc etc all come into play which can vary so called 'economy' greatly ..but for me the slight supposedly 'power' increase [ impossible to actually tell unless on a dyno ] and the 'extra' 50km from a tank do in no way shape or form make paying $50 more per tank sense .
FollowupID: 897649
Reply By: Member - nickb "boab" - Monday, Mar 04, 2019 at 22:46
We had a toyota dealer recommend using BP 98 few years ago how for our uzj v8 petrol landcruiser. while we no longer use the BP we still use 98 ~ hoping it runs better . Not cheaper ! But more ks to a tank full & cleaner motor ? .
350,000 ks & doesn't use a drop of oil .the dealer said it would take a few tanks of fuel b4 u notice much change , we think its worth the extra $$$ paid .
Cheers Nick b
AnswerID: 624214
Follow Up By: Member - McLaren3030 - Tuesday, Mar 05, 2019 at 16:59
Hi Nick,
Likewise, I had a 100 Series Petrol LC, used 98 RON for most of its 300,000+ kms. Also used very little oil, only ever had Mobil 1 engine oil.
FollowupID: 897658
