Thursday, Feb 14, 2019 at 09:57
Hi Greg,
You also appear to have a few misconceptions about the battery tech, as a 100 Ahr Lead Acid battery at the C/20 rating will do exactly that, deliver 5 amps per hour for 20 hours, which is 100. With a number of real, load tests done at work we often see good Lead Acid batteries deliver 5 to 10% above label ratings and able to do full 100% discharging. Sure the voltage tapers but then it depends on what your running, if its an inverter for your aircon unit then yes that is an issue. That's why most electronic equipment of any quality has a voltage range
If weight is the only factor it is a lot of additional money for a Lithium battery. I personally do not even use AGM as a good flooded battery out performs it by a significant number of DOD discharge cycles and only costs $280 to $300. AGM are great if your worried about spills and have restricted venting.
As for Lithium the tech is still settling in, I have personally seen more burnt out lithium batteries than I have seen AGM or Lead Acid batteries with failed cases causing damage around them. The problem is how Lithium are made and the electrolyte which is highly volatile. The Cells are typically 18650 style inside and these at a 100% charge can reach 120 PSI, which is why when they fail they tend to "vent with flame".
When the new plastic electrolyte Lithium, that is in development comes out then we will get a truly safe battery in this chemistry style.
The DOD and capacity of Lithium is highly dependent upon the chemistry type, pure lithium (Lithium Ion or Lithium Polymer) have the best weight to power ratios. Sadly they have poor cycle life. Here think mobile phone batteries. They also have superior DOD levels. To get cycle life they use nano particles in the metal lattice structure. The current choice is with Nano phosphate, which helps prevent dendrite formation. However by doing this capacity and a DOD is decreased.
If I have a 100K caravan I'm not ready based on current tech levels with Lithium to risk it with a battery that will potentially vent with flame and destroy the lot. I will consider it as the tech is more established and costs decrease.
Sure you get great voltage all the way down to flat on a Lithium, but 1 x 100hr Flooded Lead Acid Battery, 1 solar panel with reg is way less cost than 1 x 100AHR Lithium battery. With my Current battery and panel combo I have had 4 years of service and still going with a fridge that is never turned off in the car.
Lithium is simply way to expensive for what it is offering, and the current tech has not had enough time to truly prove itself for hoped 10 plus year service life.
Where as companies like US Batteries can Gaurantee it for Flooded Lead Acid
897122
