poptop caravan
Submitted: Sunday, Dec 30, 2018 at 15:31
angelo S
hi all I have an older Windsor poptop and would like to know if its possible to fit a rooftop a/c . my concern would be lifting the top with the added weight. anyone done this
Reply By: Kazza055 - Sunday, Dec 30, 2018 at 15:48
Caravan roof top air conditioners are notorious for their less than efficient operation, noise and power hungry to operate.
If it is possible I would be looking to see if you can manage to install a domestic split wall unit. The majority of new units are inverter type using much less power and being far superior in their operation/efficiency.
A roof top unit is going to make the roof much more difficult to lift plus you may need to reinforce the roof top to carry the extra weight.
622897
Follow Up By: IvanTheTerrible - Sunday, Dec 30, 2018 at 16:31
could also get flexible lines made up if you wanted to fit the head unit in the roof
895949
Reply By: Jonty - Sunday, Dec 30, 2018 at 18:50
We fitted a Dometic air con to our 17 ft Millard (1997 model) pop top.Had to put braces across the roof. Made it bit heavier to lift, but doable. Hope that helps you.
Cheers.
622900
Reply By: Kazza055 - Sunday, Dec 30, 2018 at 19:19
Here is another option for you to look at -
Truma Saphire Underbunk Aircon.
This would be an easier install as there is no flexible connections needed.
Our first van was a 16' Jayco Poptop and it had a split system with the compressor in the corner cupboard and the head unit in an overhead cupboard.
Like all or most caravan air conditioners, they tend to be using old technology and are nowhere near as efficient as the domestic units.
622902
Follow Up By: Jarse - Monday, Dec 31, 2018 at 16:04
We have a Truma Saphir in our camper (AOR). It works
well, and runs fine on either the Yammy or Honda 2.0 gennies (if you need to). I haven't really tried the heat cycle on it, as we have a diesel heater installed.
It's reasonably quiet, too.
895968
Reply By: Erad - Monday, Dec 31, 2018 at 08:10
A friend of ours had a rooftop A/C fitted to his poptop caravan. The roof was so heavy then that they had to use props to hold up the roof until he got the gas struts regassed with more gas until they were strong enough to lift and support the roof by themselves. Before that, he had to use a broom to lift the roof because of limited access over the double bed.
As stated above, a domestic A/C unit is much more efficient and quieter, but the big problem is "Where do you mount the Inside unit?" Also, I am a bit unsure about the long-term life of the domestic unit - are they up to vibrations involved in travel? They are still gassed under pressure whilst travelling, even though they are not being used at the time.
The units which go under the bed are my preferred option at present. When I tested one, I thought it was noisy, so I opted for the Ibis split system. In retrospect, that is just as noisy. I have to advise the local Dept of Civil Aviation that I am turning it on in case they think an unidentified aircraft is passing through their patch. Our A/C is noisy inside the van, but when the temperature outside is 38 Deg C, the noise is better than the heat.
622907
Follow Up By: angelo S - Monday, Dec 31, 2018 at 12:11
I have heard the vibrations of road driving is not very good for the domestic splits that's why I have shied away from that idea. Theres not a lot of room inside my van as
well which is why im looking at a rooftop option.
thanks for your msg.
895960
Reply By: Member - Racey - Monday, Dec 31, 2018 at 12:01
Hi, 2 months ago I would have agreed that roof A/C's are noisy. We recently replaced our old unit with a new Dometic Harrier Inverter model and very pleased with the result.
Jon
622910
Reply By: Batt's - Tuesday, Jan 01, 2019 at 14:27
We had a 1986 Jayco pop top in 2005 had a split system fitted by removing the rear window they are super quiet and the compressor was mounted below it on the vans rear bumper with a few mods.
We had no problems when travelling done half the country and several other long distance trips all on road.
622943
