Sunday, Nov 18, 2018 at 17:24
Hi Chris - I bought a Chinese no-name cheapy for about $27 from memory, about 5 or 6 years ago. Got it off some place like Crazysales.com.au.
It worked reasonably
well, but the lid retention lugs were made of plastic and they just popped into their locking position with springs that were compressed with push buttons.
The setup lacked adequate clamping force on the lid, so I usually had to lean on it a bit, to get a good vacuum seal.
I've still got it, it still works O.K. - but now I use it for packaging protection for new spare filters and small workshop parts, that need protection from corrosion and dirt.
I bought a mid-range Luvele off eBay early last year (they have their own website as
well), and it came with a package deal that included glass containers with special lids that you hook up a hose and connectors to, to suck the air out of the glass containers.
I seem to recall it was around $99 for the Luvele sealer and another $30 for a set of the glass containers.
The glass containers are oven-proof, microwave safe, and dishwasher safe, as they're borosilicate glass, like Pyrex.
We use the glass food containers at
home, vacuum packaging makes most foods last longer.
You'll find there are some foods that vacuum pack and last better than others.
Vacuum packaging in the glass containers tends to suck the moisture out of juicy foods, drier foods vacuum pack better in the glass containers.
Using the food storage bags is good for full cooked meals or chunky soups when travelling - but you have to watch out for excessive juices or liquids getting into the seal when sealing, this will stop effective sealing.
You can store the vacuum packed items in either fridge or freezer - but freezing them makes them last a lot longer.
Some foods freeze O.K., some are not so good, after being frozen - they lose flavour and texture if frozen. It's a matter of trial and error.
The rolls are readily available from K-Mart, Target, Woolworths and Coles and camping supplies
places.
I've found the Sunbeam brand rolls are more expensive, without any real advantage.
I seem to recall about $28 for 2 Sunbeam rolls, and about $20 for 2 K-Mart rolls.
They come on special occasionally, so they often come down 25% on those prices.
Watch out for sizing of the rolls and the machines.
There can be several widths in the vacuum sealers - some are 26cm wide, some are 28cm wide, some are 30cm wide - and the rolls also vary in width, according to where you purchase them from.
The roll needs to be a good fit, width-wise, in your machine.
When sealing, you must ensure there's no wrinkles in the sealing joint, which means being careful to stretch the PVC bag out, so it's sitting flat on the sealing element contact points.
Wrinkles in the seal means the seal won't be air-tight, and you risk food leaks and air getting into the bag, and reducing shelf life.
Don't know of anyone re-using the bags, I don't think it's worth the effort - but I store bacon in them, and when I take several slices of bacon out of the bag, I cut the bag down, and re-seal it again.
On the subject of food storage, I've found a neat trick to preserve the lifespan of fresh vegetables.
Don't just throw them in the vegetable crisper when you buy them - wrap them in a couple of layers of paper roll towel, nice and snug - then store them in the vegie crisper.
The paper roll towel appears to be just the right level of vegetable protection to allow the vegetables to breathe, and to stop them from drying out, or becoming limp or rotten.
The paper towel also seems to inhibit any attack by mould spores or other food-spoiling bacteria that inhabit the crisper.
I've found the paper roll towel trick extends the life of fresh vegetables by at least a week, sometimes two weeks.
If you use a part of the vegetable (say, cutting a 1/4 off the head of a cabbage), just re-wrap the remainder of the vegetable in the paper roll towel again, and it will go on extending the life of the remnant vegetable.
Cheers, Ron.
622204
Follow Up By: Allan B (Sunshine Coast) - Sunday, Nov 18, 2018 at 18:57
Hi Ron,
You say...." I've found the Sunbeam brand rolls are more expensive, without any real advantage."
I have found anything from Sunbeam is more expensive, without any real advantage! I have been called upon to repair a number of Sunbeam appliances and you would swear that they are constructed to defeat access for repair. I have in earlier times bought Sunbeam only to later regret it. I won't go near their stuff now. So there!
However, on the subject of wrapping vegetables in paper I wholeheartedly agree.
I learned the trick from the Beadells, Connie and Mick. When they 'go bush' it is for five months at a time. They wrap every piece of vegetable separately in newspaper and then carry it in a cardboard box, not plastic. Their vegetables stay fresh for many weeks.
Incidentally, the Beadells carry no refrigeration or icebox. Their diet is contrived to food that will survive without refrigeration, or vacuum packaging for that matter. I think of them when I see people with 90 litre fridges plus 50 litre freezers. I know, I know, each to their own, but it can be done if you are tough! lol
894964
Follow Up By: Ron N - Sunday, Nov 18, 2018 at 22:10
Allan - "I have been called upon to repair a number of Sunbeam appliances and you would swear that they are constructed to defeat access for repair."
So you apparently missed the little decal on every household electrical item today, that says, "No User Serviceable Parts Inside"! [;-)
IMO, the paper roll towel works better than newspaper. I've tried newspaper in the past, and even though newspaper does improve the life of the vegies, the paper roll towel appears to have just that right amount of "breathability" and absorbency, that seems to do the trick perfectly.
In the bad old days, we didn't know what fresh vegies were! The only vegies we got, when in the bush, came in a can of Tom Piper Irish stew! LOL
I can remember the brother buying a can of "French Bacon Consomme" soup, thinking it could offer something a little superior to the regular diet of canned meatballs and spaghetti, or Tom Piper steak and onions.
We watched as he heated and opened it - and sighted his total disgust, as he viewed the watery contents, as he poured it into his bowl!
I can still recall his disgusted comment - "Bacon soup!! This is just the water they washed the pig in! ..."
Dad thought it that funny, he lost it, and was laughing until the tears ran down his face.
It was all too obvious, the brother had no idea what "consomme" was in French cuisine terms - and I can tell you this much, he never bought any more "French" food, in cans!!
Cheers, Ron.
894967
Follow Up By: Allan B (Sunshine Coast) - Sunday, Nov 18, 2018 at 23:25
Ron, I wasn't a "user"...... I was the serviceman.
I'll pass on
the tip re the paper roll towel when I next see the Beadells. lol
894968
