Thursday, Oct 11, 2018 at 12:55
Nutta
If the previous setup worked the fridge ok then something now must be different.
Nice to have 2 DCDC units to use but I am curious as to how the anderson plug will be reading 14.5v. Even IF the alternator was producing 14.5v at the alternator terminal, the cable and anderson plug whilst under load of the fridge isn't going to read 14.5 v, it should be less if running the fridge 12v element. If it is very close to, or at, the alt voltage then it would seem the fridge isn't using current or very little. Either way not much cooling will happen.
So, even if you add the relay Allan suggests and supply the trailer DCDC and the fridge from that line, I would think you will still have the same problem.
Have you isolated the fridge supply and directly fed the fridge with power to see what happens, as a
test? Perhaps testing the fridge current draw amp flow while delivering a constant 14v to it may show what is happening. ie testing by eliminating all the cables, anderson plugs etc. Unless you know the fridge is working as it should, ie, do basics first, your refurbishement may not be aimed in the best directions.
894054
