electrical problems on gu patrol
Submitted: Saturday, Jun 12, 2004 at 08:42
snowman
I have a GU Patrol that is blowing the tail lights/dash light fuse. The vehicle has been to the dealer twice so far but after 5-10 minutes fuse blows still. Originally the fuse would blow every time you replaced it but now takes 5-10 minutes or maybe when i hit a bump in the road. I also noticed the other day while driving it that it would idle fast (1100rpm) when not in gear, put it in gear it would idle at the normal speed. The vehicle is also fitted with cruise control so I dont know whether this could be part of the problem.
Reply By: Bilbo - Saturday, Jun 12, 2004 at 12:50
I can support Phil's statement. My Yota LC100 recently had a Kaymar wheel carrier fitted and part of that fitting was to fit supplementary rear lights. The wheel carrier block the passenger side rear lights.
The wheel carrier was fitted about 8 months ago, and it took this amount of time for the fault to develop. The fault took the form of the passenger side indicators operating in a very dim fashion and the remote door locking wouldn't work. It was the latter problem that made me go to a Yota dealer as I suspected it was the remote at first and didn't put 2 and 2 together.
They couldn't fix the remote and asked me to book it in for thier auto leccy to have a look at it. Over the weekend, prior to booking, I thought "Hmm. the dim indicators and the remote failed at about the same time".
Off with the lense covers on the supplementary rear lights and sure enough the wires had been crushed by the aluminium barrier plate between the indicator bulb and the stop/tail bulb - but only just, barely exposed the wire conductor through the insulation on the indicator wiring. I rearranged the wiring to pass through the barrier in the cutouts designed for that purpose and BINGO - indicators were OK and the remote worked perfectly.
But it took 8 months for that 'low load' short to develop.
Another prob on my old diesel Ford Mav ute was caused by the reversing light switch on the gearbox top, developing an internal short within the switch. This led to to some very strange things happening - blown fuses, dash lights dim and strange combination of lights coming up on the dash AND a total failure of engine managment system. It wouldn't start - sometimes. Wouldn't idle - sometimes. Pulled the wiring from the back of the switch at the connector - BINGO. No more problems.
The above prob happened way out in WA bush about 300 kms North-East of
Leonora. "Not nice Nissan, Bad Nissan, Nissan get bum smacked, scaring Bilbo like that, Bilbo maybe walk back to
Leonora, Bilbo alone in bush"
Bilbo
62878
