Duel Battery maintance
Submitted: Wednesday, Jul 04, 2018 at 10:06
wato35
Can you run deep cycle batteries down and just charge them up when required, or
must they stay charged all the time?
Reply By: Athol W1 - Wednesday, Jul 04, 2018 at 10:44
Wato35
ANY battery will last longer if it is kept in a fully charged state, it is not advisable to let any battery run down to its considered flat state of charge and not take action to return it to a fully charged condition.
Any battery that is left in a state of discharge will very quickly become totally unusable.
Athol
619940
Follow Up By: Malcom M - Friday, Jul 06, 2018 at 09:41
Not so.
LifePo4 prefer to be stored in a slightly discharged state.
892305
Reply By: HKB Electronics - Wednesday, Jul 04, 2018 at 11:39
As Athol wrote you shouldn't run them down to far, preferably not below 60% for deep cycles or there abouts, and they should be fully charged ASAP after being discharged. They should be stored in a fully charged condition and have a regular maintenance charge whilst stored.
619941
Follow Up By: Stevo_62 - Wednesday, Jul 04, 2018 at 19:33
Is it ok to leave battery hooked up to solar panel 24/7 when not in use ie in storage?
892270
Follow Up By: Athol W1 - Wednesday, Jul 04, 2018 at 19:57
Steve
The simple answer is YES, provided that you have a suitable charge regulator fitted in the system and that regulator would preferably be a multi stage type battery charger that accepts solar input.
Athol
892271
Reply By: Member - William B (The Shire) - Wednesday, Jul 04, 2018 at 13:42
Hi wato35,
As already stated keeping them charged is ideal, and with the price of the smart chargers being a reasonable price it is easy and cheaper than letting your batteries die.
William
619942
Reply By: kgarn - Wednesday, Jul 04, 2018 at 17:18
The statement that :
"ANY battery will last longer if it is kept in a fully charged state"
is probably true for Lead Acid/ AGM batteries etc but not true for Lithium batteries for which it is generally recommended that they be stored at less than fully charged.
Ken
619945
Reply By: AlanTH - Friday, Jul 06, 2018 at 09:11
I always plug the van into the power when at
home and let the Ctek look after the Delkor 80ah battery. 7 years old and just changed it for a new one.
80ah is all we need for the lights as we don't run much in the way of electrical stuff when away.
Compare that to the constant purchase of new batteries for the Cooks Camry which I'm afraid to say I neglected battery wise.
I could have saved a few bob by buying a Ctek years ago but didn't for some reason.
Keep it charged and it'll last much longer.
AlanH.
619971
Reply By: Batt's - Friday, Jul 06, 2018 at 17:15
With the amount of different types of deep cycle batteries available it may help to mention what type your specifically looking at.
619992
Reply By: Member - Mark C (QLD) - Friday, Jul 06, 2018 at 19:17
My two 110amph batteries in my Complete
Campsite Exodus are 7 years old and still hold full charge. The camper is stored under an awning and has light to the 135watt solar panel so is constantly trickle charged through the MPPT charger and then the DC/DC charger. The Ctek 25amp charger does the job before each trip and when in caravan parks but usually only a couple of times a year as we generally
bush camp.
619998
