Split system aircon on motorhome
Submitted: Tuesday, Jun 05, 2018 at 17:40
ThreadID: 136802 Views:5371 Replies:6 FollowUps:10
Toying with fitting a split system airconto motorhome Powering will be no problem with a powerful lithium solar setup .My inquiry to any whohave a rear mounted outer section is do you have problems with dust mud etc affecting the performance of the system .
Thanks in advance
Mary
"Some people walk in the rain,others just get wet."
Reply By: HKB Electronics - Tuesday, Jun 05, 2018 at 18:20
How much solar do you have?
AnswerID: 619373
Follow Up By: RMD - Tuesday, Jun 05, 2018 at 19:14
Wouldn’t it have to have a massive lithium multiple battery setup and also the whole motor home covered in solar panels? Can’t imagine it is possible to sustain the current requirements for a split system.
FollowupID: 891634
Follow Up By: Frank P (NSW) - Tuesday, Jun 05, 2018 at 20:09
Kimberley Kampers has found a way to do it on their Karavans and Kruisers with, IIRC, 400Ah lithium and 520 watts of solar.
FollowupID: 891635
Follow Up By: HKB Electronics - Tuesday, Jun 05, 2018 at 21:47
Know someone who had one, they said it didn't work. Kimberly state 2.2kW cooling, if you allow 1kw draw then your 400Ah of lithium would last about 5 hours at night, 50% duty cycle say 10 hours. Not really particle.
Be interested to hear from others who have one how they well they work off batteries?
FollowupID: 891639
Follow Up By: Keith B2 - Wednesday, Jun 06, 2018 at 07:57
My build will have a little Toshiba split system running of 400 AH Lithiums with about 1Kw of thin film solar panels. For me the key is to run the aircon overnight on its low setting and just cool enough for a comfortable night's sleep.
The power draw on low setting is a little over 200 watts. On my sums and allowing for losses, the batteries should return to full charge by lunchtime if there is full sun.
Soplar 4RVs has a very handy solar calculator which I used to double check my fugures.
Solar calculator
FollowupID: 891648
Follow Up By: HKB Electronics - Wednesday, Jun 06, 2018 at 11:20
Keith B,
I take it your looking at an inverter unit?
FollowupID: 891655
Follow Up By: Keith B2 - Wednesday, Jun 06, 2018 at 11:44
Correct. I think the roof mounted RV ones are old technology and very noisy to boot. The one I have selected is this one: RAS - 07BKV - A1.
Here's the link: Small Toshiba Aircon
This was the smallest I could find in a reputable brand. But the warranty disappears as soon as you put it on a caravan. I am doing a dry fit with it now.
FollowupID: 891657
Follow Up By: RMD - Wednesday, Jun 06, 2018 at 17:13
Keith B2
You need an 12v or 24v to 240vAC inverter first don't you? after that the inverter of the aircon then does it's thing with that power.
Two lots of power conversion does mean losses to some degree, all of which have to be factored in as the total drain amount of AH on any battery type or solar system.
FollowupID: 891664
Follow Up By: Kazza055 - Wednesday, Jun 06, 2018 at 18:32
Have a look over at Caravaners Forum, there are many there that are fitting domestic splits (inverter type) and running them of solar.
FollowupID: 891670
Follow Up By: Keith B2 - Wednesday, Jun 06, 2018 at 19:41
I ave a 1.4Kw Victron inverter charger to occasionally work the microwave while the aircon is on.
I have allowed for 20% losses in the inverter and wiring, which I think is more than enough.
You can see my build on Myswag/ My camper trailer build/ World's Slowest build".
World's Slowest Build
Keith
FollowupID: 891673
Reply By: IvanTheTerrible - Tuesday, Jun 05, 2018 at 22:02
To answer your actual question. Most I have seen have the unit covered while not in use usually with canvas
AnswerID: 619376
Reply By: HKB Electronics - Wednesday, Jun 06, 2018 at 09:40
If you stick to the black stuff then probably nothing required but I would put a cover on it.
If your going to be traveling gravel and dirt roads then dust will be an issue, the red dust gets into everything and will quickly gum things up once wet so make sure cover well and plug up any holes while travelling.
Stones are an issue to, they will fly around and bounce along under the van, they can cause a lot of damage even to the rear of the van if the have something to ricochet off.
AnswerID: 619379
Reply By: Keith B2 - Wednesday, Jun 06, 2018 at 11:52
I think you can hose the outdoor units out.
AnswerID: 619383
Reply By: GerryG - Wednesday, Jun 06, 2018 at 18:25
We are on a 24volt stand alone system on our property and I wanted to put a small air cond. in our bedroom. After a lot of research I decided on the Daiken Cora range. The smallest one they had is the 2kw unit that cools only.
This unit has a 5 star rating. It works well. Might be worth looking at.
AnswerID: 619391
Follow Up By: Keith B2 - Wednesday, Jun 06, 2018 at 19:34
Thanks Gerry,
To get a bit of extra cooling, I paid a premium price and put a Daiken 5Kw in my office some years ago and it conked out after four years. So I have kinda lost faith in the brand. The original no name brand was still running after 14 years.Replaced the Daiken with a Mitsubishi and still running 8 years later. I do hope that yours gives you a better result. The no name is still running after 22 years.
Keith
FollowupID: 891672
Reply By: humpback - Thursday, Jun 07, 2018 at 17:34
I have a Samsung 2.5kw split system and have had it for 6 years, when we hit dirt roads i put a canvas cover over it and never had a problem. I have a 2000 watt inverter and 4x120amp deep cycle batteries and i would never try and run the unit on the batteries.I have installed a plug directly to the air condition unit and start up the 2.4 yamaha generator and it only runs the A/C by doing this i get 8 hrs running out of a tank of fuel Hope this helps.
Baker
AnswerID: 619406
