Monday, May 21, 2018 at 13:05
Agree with above - depends on what it is you are "planning"... some trips require time to do research about the route, apply for and wait for permits to come through etc. Some people might take this opportunity to update their computers, software, mapping etc. (Anything technical is time consuming and should not be left to the last minute). Have to review how you mount/use/charge the device.
Check downloads work offline etc.
Other trips require little route planning as you know where you're going, or have been there before etc, but require shopping for equipment, servicing of vehicle, modifications to vehicle etc.
So in general if we're going away - anywhere, we get out all our
camping equipment and set it up -
check for holes,
test cooking gear etc make a note of anything needing repairs and then set make a shopping list and get it sorted. The longer you have to do that the better.
Same with vehicle - get it out and give a full service yourself or book in - whatever is right for your circumstances.
Check all
suspension, brakes, oils, filters etc.
Check your spares, update as required.
Check tyres etc.
Same with cooking gear -
check nothing's missing, broken, dirty from storage etc.
We don't get to travel often enough so strip our vehicle back to standard config to use the 8 seats for practicality around
home so if going on a trip we need a day to re-install the rear draw system, cargo barrier, fridge slide, roof basket etc.
We typically then have to spend 6-8 weekends checking/testing our equipment/vehicle and noting things to repair/purchase. If we can spread this out over a longer time period all the better. I am normally under pressure with the food tubs - for a remote trip I pack 3 tubs - one for equipment, other 2 for unrefridgerated food stuffs, and depending on the trip I get a section of 1 roller draw (dark, cool - for veggies/fruit). The food planning I do at night after work - write a list, buy the food, and get this packed into tubs the weekend before the vehicle is packed. We always do the final "pack" of the vehicle the day before we leave. We always have a drama - something brakes/or is realised omitted during the final pack putting pressure on getting replacement before departure or there's a drama with work - a customer, software update, site update etc putting a spanner in the works. Such a drama is necessary to enjoy the trip departure with a big sigh of relief. Thank god we're away! We need a rest LOL.
619052
