Nitto Connectors
Submitted: Thursday, Mar 08, 2018 at 17:22
ThreadID: 136381 Views:10089 Replies:5 FollowUps:2
Hi All, Can anybody tell me if it's feasible to use Nitto air line connectors for water?
Reply By: Ron N - Thursday, Mar 08, 2018 at 18:10
Hi Greg - Yes, provided you use genuine Nitto Hi-Cupla Ace, plastic connectors, and not steel ones.
These Hi-Cupla Ace couplers are designed for use with air, water, and inert gases and are made from POM (acetal copolymer) and PBT (polybutylene terephthalate).
These plastics are high strength thermoplastics produced specifically for engineering purposes.
http://www.nitto-australia.com.au/pdfs/products_423_413.pdf
The problem with steel Nitto airline connectors are twofold -
One - even if you use genuine stainless steel connectors, there are still components in the connector that are not stainless and not corrosion resistant - such as springs and balls and valve components.
Putting water through these couplers will result in component corrosion, causing great difficulty in the operation of the connector.
Two - there are a lot of non-genuine Nitto couplers that are lower quality than the genuine Nitto couplers.
The "stainless" components in these aftermarket couplers will rust just from using air! - such is the low levels of chromium in their "stainless" steels!
Nitto specify exactly what the proposed liquids or gases are, that can be used with their various types of couplers. Stick with their advice and you won't encounter any problems.
Cheers, Ron.
AnswerID: 617424
Reply By: Member - ACD 1 - Thursday, Mar 08, 2018 at 19:01
Your post doesn't allude to why you want to use NITTO fittings specifically, but there are specific water fittings for campers,trailers and caravans. One type are John Guest plumbing fittings (you can also get knock offs of these).
They are designed for push together fitting during construction, are made for hot and cold water, handle constant pump pressure and have the NITTO style bayonet quick connect for hoses etc.
Anthony
AnswerID: 617425
Follow Up By: gbc - Thursday, Mar 08, 2018 at 20:57
Our camper has John guest and staino nitto fittings. It works well.
FollowupID: 889095
Reply By: Michael ( Moss Vale NSW) - Thursday, Mar 08, 2018 at 21:24
I use DME Water fittings for our Onboard Shower setup, common in the plastics and diecasting industries. similar to brass hose fittings only much better quality and operation. Hot and Cold water use. Michael.
AnswerID: 617428
Reply By: Greg A6 - Friday, Mar 09, 2018 at 16:04
Thanks very much folks. As usual, a goldmine of information.
AnswerID: 617449
Reply By: Member - Boobook - Saturday, Mar 10, 2018 at 18:10
Ive used nitto stainless connectors for water for years.
No problem.
AnswerID: 617473
Follow Up By: 9900Eagle - Saturday, Mar 10, 2018 at 19:26
Yep, same here with no problems.
FollowupID: 889139
