UHF Antenna
Submitted: Sunday, Jan 28, 2018 at 14:49
Kilcowera Station Stay
Hello forumites. Some time ago I had a new antenna installed on the gutter above the passenger door on my Hiace bus. All was good for about 8 months and then the metal bracket that was attached to the gutter snapped in half. No good anymore. So next time I was in the city I took it back to the place, told them what had happened and was pretty much told " hard luck". The bus doesn't have a bull bar and the only other option would be to drill a hole in the roof to install another antenna which I don't really want to do. Is it possible to buy a magnetic antenna for a UHF? Or have one made do you think? Thanks and cheers Toni
Reply By: Member-George (WA) - Sunday, Jan 28, 2018 at 15:00
I have a magnetic base for
mine, sits on top of my ute cabin roof. Works good, but the antenna lead is fed into the cabin through the small quarter window on the drivers side. You should be able to buy the base separate, the antenna just screws onto it. Can't remember where I bought
mine, that was 25 yrs ago. Cheers.
616423
Reply By: David G (WA) - Sunday, Jan 28, 2018 at 15:04
G'day
Kilcowera Station.
You can buy a magnetic base and fit a screw on UHF antenna no problems. You will need to run the coax from the base into your vehicle, which I presume you do know.
No sure where you would buy one but where you bought the gutter mount may be a start.
David
616424
Reply By: Member - cruza25 - Sunday, Jan 28, 2018 at 15:10
GME do a magnetic
Mag mount
Might do the trick.
It has a thinner cable so you can maybe tape it in the door surrounding in to the cab
Mike
616425
Reply By: 2517. - Sunday, Jan 28, 2018 at 15:12
Depending what type of mirrors you have you can buy mirror brackets.
616426
Reply By: Sir Kev - Sunday, Jan 28, 2018 at 16:00
Why not use a gutter mount again??
GME manufacture them -
GME Gutter Mount
Cheers Kev
| Russell Coight:
616428
Follow Up By: Sir Kev - Sunday, Jan 28, 2018 at 16:03
Donald Thompson Electrical
23 John St,
Cunnamulla
QLD 4490, Australia
07 4655 1359
Is the closest Stockist of GME products, give them a call they may be able to order one in for you.
Cheers Kev
| Russell Coight:
887799
Reply By: Michael ( Moss Vale NSW) - Sunday, Jan 28, 2018 at 16:29
Maybe just but a better quality gutter mount, Michael
616430
Reply By: Dean K3 - Sunday, Jan 28, 2018 at 17:32
Yes you can purchase them GME part number AB406 and then fit a suitable antenna.
However long term use of a magnetic base have an effect on paint work and possibly metal sub surface. Plus it also attracts iron oxides which will also rub on paintwork.
I'm not a great fan of GME products period, the antennas are built light on and often have a sine wave effect when traversing on rough roads - I broke one steel wound spring steel unit inside 1 1/2 days, and think the fibreglass replacement I sourced had a hairline fracture within 1 week.
Probably a better idea to think out side the square fit up a minesite bar with the hi mount brake indicators etc -wire them up so they work, and use this as a antenna mount instead.
No drilling of holes and antenna is usually very short as
Company i used to work for did many hiace people movers (tall roof 6 foot plus stand upright in it) like this for BHP and FMG and worked
For antennas we only used RFI which is trade only but any radio comms outlet should be able to supply a suitable antenna for mounting this method.
We used CD51-68-73 for the UHF this has been superseded but is still available without coax cable for "field repairs" on site CD51-68-70 field tune-able ideally with SWR meter but can be cut using a cutting chart.
This antenna is a ground independent so designed with a load coil and can be mounted on less than optimal locations ie bull bar mirror mount brackets etc.
616431
Reply By: Bob Y. - Qld - Sunday, Jan 28, 2018 at 19:27
Prestige Communications in
Perth offer "prestigious service", fast despatch & good pricing too.
Haven't checked their site for a while, but am sure they would offer a magnetic mount. In regards to fixing it on the roof, a small patch of thin plastic between the body & mount will stop any problems mentioned earlier.
616434
Reply By: Kilcowera Station Stay - Sunday, Jan 28, 2018 at 22:20
Thanks for all your replies. Dean K3 how about you come and fix it up for us? What you say sounds good, but a bit beyond my limited electronic knowledge! but you have all given me some options to consider. The gutter mount that we had was not spring loaded and it just cracked. Will get onto it when next in
Toowoomba. Or buy something online. Any more good suggestions as to where to buy would be appreciated. I don't care how the aerial is mounted as long as it works! Toni
616440
Follow Up By: Dean K3 - Wednesday, Jan 31, 2018 at 10:41
I would if I was your side of paddock, tad far from Wait Awhile.
Really need to source from a dedicated radio communications supplier not a 4wd supply
shop. Choices can be limited at times in some towns !
Think somebody-else has you covered as it is, however way I see it is if its been broken once is it worth going down same track. Better off thinking outside the square at times.
887915
Reply By: Kilcowera Station Stay - Sunday, Jan 28, 2018 at 22:44
I see there are 2 magnetic ones the AE4020 and the AE4026 on that GME website. Would one be better? More powerful? Or just more expensive?
616441
Follow Up By: ian.g - Monday, Jan 29, 2018 at 14:52
Hi Toni, If you can wait until I come out, I will bring you a GME gutter mount that I have left over from a previous life when vehicles still had gutters, is very strong and I'm sure it won't break. Cheers Ian
887824
Follow Up By: Kilcowera Station Stay - Monday, Jan 29, 2018 at 16:15
OK, sounds good Ian. Fancy you popping up on here! There is no rush. See you soonish though. Will be in touch as soon as Greg finalises his plans. Thanks Toni
887829
Reply By: Robin Miller - Thursday, Feb 01, 2018 at 09:49
