Black wolf questions
Submitted: Friday, Oct 20, 2017 at 16:24
ThreadID: 135774 Views:4800 Replies:12 FollowUps:5
I am thinking about buying a black wolf turbo lite tent. As most of my camping will be my wife and I or my son-in-law and myself.
I am unsure if i go with the turbo 240 plus or 300 plus.
Can anyone comment if the extra size out weighs the weight difference? most of my camping will be 3 to 5 days at a time. we will be using bunk beds. I like the idea of the plus so if it is raining i can set up a small table in the main area and not get wet.
Thanks and regards
Michael
Reply By: Tony F8 - Friday, Oct 20, 2017 at 21:46
Have you looked at the Oztrail fast frames, not canvas, but plenty of room, lighter and cheaper and a very usable awning, the fast frame tourer is possibly the one to look at. We bought a Coleman Gold instant up not long before the Oztrail fast frame came on the market, very happy with it, but definitely would swap it forthe Oztrail.
AnswerID: 614475
Follow Up By: Shaker - Friday, Oct 20, 2017 at 22:30
A friend of mine has a canvas business, makes camper trailer tents, awnings etc, he bought a Black Wolf Twin Turbo tent for his own use, said it couldn’t be beaten for “bang for buck” & allowing for his labour costs, he couldn’t make a tent for that sort of money.
FollowupID: 885082
Follow Up By: Dave(NSW) - Saturday, Oct 21, 2017 at 01:00
I have the 240 Black Wolf & find the stretcher beds rub on the sides of the tent, the 300 would give a bit more room. not much difference in weight or size packed up.
cheers Dave
GU RULES!!
FollowupID: 885086
Reply By: William P - Saturday, Oct 21, 2017 at 02:32
The Lite has a lighter material - not sure it is canvas as such or the polyester mix - compared to the "non" Lite versions which are made of top quality material.
Not sayin there is anything wrong with the Lite material but satisfy yourself that it meets your requirements.
AnswerID: 614478
Reply By: Dusty D - Saturday, Oct 21, 2017 at 08:07
After looking around for a tough tent that was easy to put up and pull down, I couldn't go past the Black Wolf Turbo 240 for the type of camping that I intended doing. One big 'plus' when it came to choosing the Turbo over the Turbo Lite was the floor material - a lot heavier and stronger in the Turbo and this is where the weight difference was.
The Turbo is 24 kg packed and the Lite is 19 kg, but I figured that if I went with the Lite to save only 5 kg, I would have to carry a h/d ground sheet and I wouldn't gain anything. In fact, I would lose that bit of packing space that the h/d groundsheet required and it would more than likely weigh more than 5 kg.
My wife and I use Black Wolf Mega Deluxe inflatable mattresses, very comfortable and extremely warm in sub zero temps. We looked at fold-up stretcher type beds and figured that they are okay out in the paddock, but not in the tent - prolonged use would definitely wear holes in the floor.
As for selecting the 240 plus or 300 plus, I guess you have to consider how much time you think you will spend in the tent and how much gear you will need to stow. If you are going to be set up somewhere for any length of time, the extra room is definitely an advantage, but if you are going to be on the move day after day, you need to keep it simple and apart from bedding, practically everything else stays in the vehicle.
Dusty
AnswerID: 614482
Reply By: Sigmund - Saturday, Oct 21, 2017 at 09:53
The 300plus needs a very big flat clean area. That limits your options.
AnswerID: 614488
Reply By: Member - brucek - Saturday, Oct 21, 2017 at 11:29
We have had the turbo 300 lite plus for some years now. Great tent, BUT I don't think it will be good for bunks because of the sloping sides. The bunks would have to be in the middle to get the head room. I suggest that a tent with much more vertical walls would be much better.
I agree with the others esp about a 6x3m tent; we have had to compromise on the ground condition a little more than we would have liked.
The 300 plus is much bigger in side, (about an extra 3+ sqm of floor), but I think the sides are less vertical than the 240 since they are both the same height. The extra room really increases the storage and single level bed space
We have a queen bed nearly in the middle of the tent (no pole) and that means head room (for me) is limited. Even walking around the bed means I am touching the wall often. It works well for us, with mobility issues, we have the commode over the portaloo right next to the bed, and we do light cooking in the tent with a camp stove.
BTW I can pitch and pack the tent single handed. The ugliest thing is lifting it into the car. We have built an igloo/tunnel to slide the tent in and out underneath the other luggage. Tents are often first out, last in.
AnswerID: 614493
Reply By: ian - Saturday, Oct 21, 2017 at 11:29
Michael,
I have had lots of tents and now have had a Turbo lite 300 for a few years. great tent. Wouldn't change it. Maybe you should not get the "plus", but buy the sides for the verandah for use when it is raining instead?
Cheapest I found was at Snowys. They were good also.
ian
AnswerID: 614494
Follow Up By: Michael R26 - Saturday, Oct 21, 2017 at 12:50
Thanks for your reply, yes the attachable sides sound good but not sure 2 bunk beds and bags and fishing gear will be able to fit inside. some of my fishing gear is rather expensive and would feel much more comfortable inside the tent rather than outside the annex area.
FollowupID: 885103
Reply By: Doug & Alenna - Saturday, Oct 21, 2017 at 12:23
This post has been read by the moderation team and has been moderated due to a breach of The For Sale/Wanted to Buy Rule .
Forum Moderation Team
AnswerID: 614498
Reply By: Doug & Alenna - Saturday, Oct 21, 2017 at 13:44
AnswerID: 614500
Reply By: Doug & Alenna - Saturday, Oct 21, 2017 at 15:28
AnswerID: 614501
Reply By: Doug & Alenna - Saturday, Oct 21, 2017 at 16:27
We found the Turbo 240 lite ample size for 2 adult & 3 kids, see classifieds
AnswerID: 614504
Reply By: Top End Az - Monday, Oct 23, 2017 at 13:25
We have the 300 (not plus) but not the lite model. We use it for us and our son and is very spacious. We use camp stretchers inside with 4wd mattresses on top. Now our son doesn't like camping anymore we looked at the 240, but found it a bit tight inside. The 300 is good if inclement weather comes in as you can fit your table and chairs in it. From memory the tent size packed up is about 1500mm long, which means it (just) fits into the back of our Dmax dual cab.
HIghly recommend the Black Wolf range of tents
AnswerID: 614535
Reply By: Neil W2 - Saturday, Oct 28, 2017 at 09:08
Hi we have a 300 plus and it is great, spares are easy and relatively in expensive as well. The plus gives you that bit of extra when staying put for more than a few nights additional weight is minimal but overall they are a heavy tent to lug around.
The advantage of the 300 is that if you are just stopping for the night you do not need to deploy the additional space but it takes little time to do so.
if you were staying for shorter periods I would say get the 240 and front canopy ends.
My wife and I deploy a queen size bed, side tables and another bit of hanging space and still have plenty of room. inside. Using bunk beds you would easily get by with a 240 though.
AnswerID: 614628
