Suaoki Emergency jump starter
Submitted: Monday, Sep 25, 2017 at 12:29
ThreadID: 135639 Views:5875 Replies:8 FollowUps:14
Hi All,
Is anyone familiar with the Suaoki G7 unit? I purchased one June 8 this year, I charged it to 100% and stuck it under my Patrol seat. Vacuuming my car yesterday, thought I'd better check the charge level, the instructions say to top up to full charge every 3 months. So it was a week or so over 3 months, it was dead flat and it was definately turned off by the main slide switch when it was stored. Plugged it in overnight, all ok. So my point is, if the instructions say top it up every 3 months, it should have plenty of charge in it at say 10 or 11 weeks after charging! So has anyone left one longer that 3 months and still had a reasonable and servicable charge for an Emergency engine start? Thank you. Michael
Reply By: RMD - Monday, Sep 25, 2017 at 14:27
If it is the 18000mah model then there is no way it can deliver 650 amps through the jum cable size. THe potential difference available also ensure that cannot happen.
The trouble with jump starters is they go flat because they are batteries too, so unless you have charged in just before the trouble you don't know you are going to have, they will probably not start anything.
Sort of convenient, prehaps but most only assist the start and cannot perform when they are discharged.
Almost daily charge check may see it do the job as intended. Having a dual battery system I have never considered one for the reason of them being unreliable or as you found, discharged when needed.
AnswerID: 613959
Follow Up By: Michael ( Moss Vale NSW) - Monday, Sep 25, 2017 at 22:18
Thanks for you post but there a lot of guys with good results from this particular unit. Technology has moved on and a lot of the old theories have gone out the window. Regards, Michael.
FollowupID: 884518
Follow Up By: Malcom M - Friday, Sep 29, 2017 at 07:41
And that in no way addresses the question.
FollowupID: 884603
Reply By: Member - Peter S (NSW) - Monday, Sep 25, 2017 at 15:14
I have just checked mine, last charge 7 weeks ago. showing today 98%, I dont think that is bad at all. hope this helps. Pete.
AnswerID: 613961
Follow Up By: Michael ( Moss Vale NSW) - Monday, Sep 25, 2017 at 22:28
Hi Peter I was thinking that may be the case, I'll watch it over the next few months and log the capacity drop. Regards,Michael
FollowupID: 884519
Reply By: Member - cruza25 - Monday, Sep 25, 2017 at 16:23
I have the G7 charger and after 5 months showed 95%
Started my diesel Prado the other evening when the main battery was dead flat and still showed 95%
Maybe keep a note of charge date and % for a while to see if it’s faulty.
Mike
AnswerID: 613963
Follow Up By: RMD - Monday, Sep 25, 2017 at 18:31
Logic has it that if the 95% reading after a stored period and then also 95% after a start, I would suspect the display isn't a true indication of its performance.
FollowupID: 884511
Follow Up By: Member - cruza25 - Monday, Sep 25, 2017 at 19:17
Hi RMD
Not sure how much it would change after a 2 second burst to start the car.
One day I might try disconnecting the main battery and just use the G7 to start a few times and see how it reads. (Yes they are 18000ma)
A handy device though to have in the car, I can charge phones iPads and it is a torch all for $99 with a bunch of different plugs for laptops etc.
FollowupID: 884512
Follow Up By: Michael ( Moss Vale NSW) - Monday, Sep 25, 2017 at 22:31
Thanks Mike, I will log capacity drop over the next few months.
Regards,Michael
FollowupID: 884520
Follow Up By: RMD - Tuesday, Sep 26, 2017 at 14:48
cruza25
NO WAY would I ever attempt to remove the main battery and try to use the little starter pack.
If you get a voltage spike from a connection during as it starts or running you probably will destroy some electronics in the vehicle, maybe the alt reg too.
A foolish thing to try if your life isn't depending on it. If your life is relying on it, then give it a go.
FollowupID: 884538
Follow Up By: Member - cruza25 - Tuesday, Sep 26, 2017 at 16:14
Ok thanks RMD for the warning. I will give that a miss then.
Just keep it tucked under the back seat and keep it charged.
Mike
FollowupID: 884540
Reply By: Nomadic Navara - Monday, Sep 25, 2017 at 21:08
From what has been said above it seems you have a bum unit and thus you have a warranty claim. Charge it fully and check the charge level weekly. There is one report of 95% capacity after an extended time. If the charge level drops too quickly report the loss of charge to your supplier and arrange for a replacement.
AnswerID: 613971
Follow Up By: Michael ( Moss Vale NSW) - Monday, Sep 25, 2017 at 22:38
Yes Peter, tried to communicate to the Chinese seller tonight, told him what happened , he sent me the instructions and the following reply to me was to keep it charged. Typical of Chinese sellers. It's 100 % charged now, I'll log it's static discharge and see how it goes. It's unused so I think its a dud. Thanks Peter. regards Michael
FollowupID: 884521
Reply By: Michael ( Moss Vale NSW) - Monday, Sep 25, 2017 at 22:39
Thank you everyone for the replies, I appreciate the input. regards, Michael.
AnswerID: 613975
Reply By: Bob R4 - Tuesday, Sep 26, 2017 at 19:57
Just checked mine after 6 or more weeks, and showed 100%.
AnswerID: 613989
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Sep 26, 2017 at 22:06
Thanks Bob, that's a great help to me. regards, Michael
FollowupID: 884542
Reply By: Member - Stephen L (Clare SA) - Tuesday, Sep 26, 2017 at 22:27
Hi Michael
When I purchased our unit new back in April, I gave it a full charge and it then just sat in the box.
Before we went away in August, I checked it out and it still showed 100%, but still topped it up to be on the safe side.
Sitting under the back seat when we were up in Nhulunbuy, the chap next to us had a flat battery one morning and asked if I had a set of jumper leads. I said yes, but have something better.
I then get out the G7 and as quick as a flash started the diesel Captiva. The chap could not believed how good a job the small unit did, and he took a picture of it on his phone and was going to buy one when he got back to Darwin. After I tested it after the start, it still showed 100%. According to the stats, they jump start a vehicle over 20 times before they need to be fully charged again.
I told him to look around, as I ended up getting mine for $80, a reduction of $9 and I was very happy with the price, including free delivery.
Smile like a Crocodile
AnswerID: 613993
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Sep 27, 2017 at 06:46
Thanks Stephen, another good practical and positive endorsment. They seem to be a good backup for the money. It also saves hooking up your own vehicle and the worry of potential damage to electronics out in the middle of nowhere. Regards, Michael.
FollowupID: 884547
Follow Up By: Member - Stephen L (Clare SA) - Wednesday, Sep 27, 2017 at 07:11
So true Michael and to think nearly 25 years ago and well before eBay, I paid $119.95 for top set of jumper leads ..........lol
They are always in the car but to be honest they have only ever been used a few times.
FollowupID: 884548
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Sep 27, 2017 at 07:41
Stephen, True about the jumper leads, I made mine up 40 years ago with huge Utilux clamps, I still have then but they are heavy and bulky at 3 plus metres long. Also the G7 has the extra options, torch, USB charging for computer or phone and flashing lights may be handy for a busy road breakdown or accident. How things have changed. regards, Michael
FollowupID: 884549
Reply By: Malcom M - Friday, Sep 29, 2017 at 07:52
Being Lithium, it shouldn't have any self discharge although its management electronics would drain a little bit over a long period.
If it keeps going flat then it likely has issues.
Totally flattening lithiums is generally instant death to the cells.
AnswerID: 614039
Follow Up By: Michael ( Moss Vale NSW) - Friday, Sep 29, 2017 at 10:15
Thanks Malcolm, Yes its something i will watch closely. regards, Michael
FollowupID: 884605
