Friday, Aug 25, 2017 at 11:53
Lets start at the very beginning, because it's a very nice place to start.
A/ so we have a dual axle trailer with 4 wheels.
B/ exactly what axles, hubs and wheels do you have?
Is it 2 tonnes combined or 2 tonnes each axle?
What is the current plated GVM of the trailer?
C/ What are you actually trying to achieve?
If you are trying to recompliance with a higher GVM ..... that could be more expensive and complicated than you may be prepared for.
IF you are simply looking for a stronger
suspension with the same GVM, that is another story.
You can do 1.5 tonnes per axle on ford bearings.
IF you have 45 or 50mm axles and you are running Ford bearings you may already have 1.5 tonne axles.
AND those load capacities can be achieved on 14 inch light truck tyres
Remember this is bearings ..... not stud pattern.
Now if you want 3 tonnes per axle ...... yeh
well the game now gets far more expensive, particularly if you want a 6 tonne GVM.
You will be on 6 stud rims and 15 or 16 inch tyres.
AND
That takes you out of the light trailer catagory and you will be towing with a truck on a truck license.
If you have 2 tonne axles, they will be at least 50mm and you will be running landcruser or some other 2 tonne specific bearing
Most commonly you will be running 15 or 16 inch tyres, though there are some specifically made 6 stud wheels that take 14 inch tyres and if you are very specific about the tyres you can run 2 tonnes on 14 inch light truck tyres (just)
SO
Back to the ABC and the doug ray me
613303
Follow Up By: humpback - Friday, Aug 25, 2017 at 13:46
Thank you to every body who took the time to reply especially you Bantam,I have spoken to G&S Chassis who informed me that to run 3 ton springs i would have to change my axles from 50mm to 65 mm change the brakes and a few other expensive things at a cost of around $6000 i think i will leave as is.
Baker
883708
Follow Up By: PeterInSa - Friday, Aug 25, 2017 at 20:33
If you have a G&S Chassis the chassis should have a G&S Chassis ID plate with from memory the GTM printed on it. Its on the inside of the A frame
Am Interested in the GTM figure. And Do you have 2 axles.
883724
Follow Up By: humpback - Friday, Aug 25, 2017 at 21:41
GTM is 4 ton and it is a dual axle.
Baker
883728
Follow Up By: PeterInSa - Saturday, Aug 26, 2017 at 09:51
Baker, need your email address for an upgrade solution, send it to PeterInSa@yahoo.com.au
883733
