UHF Radio
Submitted: Friday, Aug 18, 2017 at 19:46
ThreadID: 135423 Views:4821 Replies:9 FollowUps:9
Hello fellow members ,I have a problem I hope to get some advice on .I have a GME UHF radio with the remote controls in the handpiece ,the problem I am having is that I can receive conversations ,but cannot transmit and nothing comes up on the hand piece shows that it is TX ,any ideas what to look for before I take it somewhere to get looked at ??
Reply By: Bob Y. - Qld - Friday, Aug 18, 2017 at 21:59
Microphones are the weak point, maybe after aerials, of any UHF, John.
I'll donate a clutch of sucking pigs to the orphanage if it's not in the lead of the mike, or the PTT switch.
AnswerID: 613178
Follow Up By: Allan B (Sunshine Coast) - Saturday, Aug 19, 2017 at 08:48
Yes, I'd agree with Bob and contribute a box of apples for the sauce.
Especially as "nothing comes up on the hand piece shows that it is TX".
FollowupID: 883565
Follow Up By: MUZBRY- Life member(Vic) - Saturday, Aug 19, 2017 at 08:56
Gday
What time and where is dinner, ill even help clean up after.
FollowupID: 883566
Follow Up By: RMD - Saturday, Aug 19, 2017 at 09:33
They would then be part of the "stolen generation" I presume!
Pork Belly is a bit thin on a suckler though.
Second thoughts, sell the pigs and buy a new mic.
FollowupID: 883568
Follow Up By: ian.g - Saturday, Aug 19, 2017 at 15:54
You're a good man young Bob, but hang onto the suckers and keep them on feed until next year when the Matilda Center opens again, they will be just right for doing pig on a spit then, and with the donation of the box of apples from Allan we might all get a feed. I think you're right though with your presumption of the problem being in either the lead or mike, very seldom see problems with the set
Cheers Ian..
FollowupID: 883572
Follow Up By: 9900Eagle - Saturday, Aug 19, 2017 at 20:57
Bob, by any chance do those pups have a big black mamma and papa or are they piebald.
FollowupID: 883578
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Aug 19, 2017 at 23:09
Bob!
Do you have a pic of those pigs handy? Michael
Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.
FollowupID: 883581
Reply By: Frank D - Saturday, Aug 19, 2017 at 11:10
Hey John I have GME with remote mic and had the exact same problem could receive but could not transmit.
This was a year or about 18 months ago.
There was a known problem with this unit and if I remember rightly it was a diode or resistor or something that was blown,rang GME and they repaired it but charged me because it was 6 or 7 years old and out of warranty,I may still have the paper work.
It was not a problem with the mic. I suggest you ring GME first.
Hope this helps.
Frank
AnswerID: 613183
Reply By: ken triton - Saturday, Aug 19, 2017 at 13:18
Hi John
I had the same problem with my GME TX3440 on my last trip, took it to a radio tech and he tested it, but before I took it there he said it's probably the transmitting chip, said it was a common problem. Anyhow that's what was wrong with it so I bought an new 80 channel radio instead. Not saying that's what's wrong with yours but it could be.
Ken
AnswerID: 613185
Reply By: Dean K3 - Saturday, Aug 19, 2017 at 19:53
As you haven't advised whihc model you have bit hard to narrow down to specific model GME have several types of radio with channel selection capability and display in the range.
easiest soloution see if you can grab another mic from somebodyelse see what happens if not the mic then its component failure and off to the bench tech for servicing.
The downside of this servicing is costs about same as purchasing a new radio $250 was last fixed price servicing I paid on a vertex land mobile.
Do pay for what you get with most UHF CB radios going around a few exceptions though
AnswerID: 613189
Reply By: MEMBER - Darian, SA - Sunday, Aug 20, 2017 at 11:05
And....if you do need to get a new radio, consider one with the 'micro-techno'* bits back in the main body...I'm sure that mike would have heaps of delicate micro components that are easily damaged in use. Even though it can be difficult to find a mounting place for the larger body radios, reliability is vital.
As an aside...re a 12v to twin USB cig plug adaptor of mine that failed (only $13 :-)...I was amazed at the complexity inside...p circuit board, lots of small and tiny thingamies* soldered in...probably entitled to fail after a year or two of vibration and knocks.
*as you've guessed, NASA won't need my help any time soon.
And2...while GME is a great Aussie brand with lots of happy users, don't discount Icom and Uniden...also great function and reliability.
AnswerID: 613203
Reply By: Member - Bigred13 - Sunday, Aug 20, 2017 at 16:11
Many thanks to all the fellow Explorers with your ideas on my UHF problems ,I am sorry I omitted to put the name of my set it is a TK 3300 ,been out of range for a while so will follow up on the ideas and let you know how I get on
AnswerID: 613209
Follow Up By: Dean K3 - Monday, Aug 21, 2017 at 16:59
This comes up as a kenwood unit - not a gme radio.
Kenwoods along with likes of Icom Vertex are considered low tier commercial radios and should be bit more reliable than any GME Uniden or oricom per the normal 4wd application
Think somebody mentioned it ch 21 22 are data telemetry use so hopefully you weren't trying to use these freqs for voice transmission
FollowupID: 883624
Follow Up By: Allan B (Sunshine Coast) - Monday, Aug 21, 2017 at 18:24
He meant TX3300.
FollowupID: 883626
Reply By: Member - KenD - Monday, Aug 21, 2017 at 15:14
Hi John
I have a GME TX6150 5 watt hand held. On a couple of recent trips our little convoy decided to use ch22. We could hear the others but they couldn't hear us. Reverted to my little 1 watt hand held and no problem except for limited range.
Happened again a year later so I looked at manual.
Guess what. Transmission is inhibited on chs 22, 23 (Selcall/telemetry use) and 61, 62 and 63 for Guard band channel as per regulations.
Saved me a lot of frustration and puzzlement when I found out. Hope this info is useful for you.
KenD
AnswerID: 613227
Follow Up By: Member - Bigred13 - Monday, Aug 21, 2017 at 16:35
Hi KenD , Well thanks for that info ,guess what channel I was using ,yes 22 ,so I will bear that in mind next time I am using it,thanks ever so much
Regards John
FollowupID: 883623
Reply By: Allan B (Sunshine Coast) - Monday, Aug 21, 2017 at 18:32
Hi John,
You need to familiarise yourself with the appropriate UHF channels.
This Link may be of use to you.
AnswerID: 613231
Reply By: Member - KenD - Tuesday, Aug 22, 2017 at 22:50
Hi John
If button beep is on, a channel which can't transmit will beep twice when you press to talk. So knowing that is useful if you forget which channels not to use. Of course, don't forget that chs 5 and 35 are reserved for emergency use.
Your question had me scouring through the manual but with some leisure rather than trying to work it out on the run. I learnt a lot. So thanks for the catalyst.
KenD
AnswerID: 613249
