Problem with Gel Battery Banks in C/Van
Submitted: Sunday, Jul 16, 2017 at 21:00
ThreadID: 135267 Views:4516 Replies:4 FollowUps:43
Until just recently I have had 2 x 6v -200ah SunGel Batteries (made year 2000) as one bank and 6 x 2v -250ah Sungel Batteries (made year 2002) as a second bank in my caravan. (15 years for the 2 volt is not a bad run, the 6 volt are 17 years old and still going well)
A master switch allows 1st bank only or 2nd bank only or both banks to be on or for both banks to be off.
Solar panels on the roof supply to which ever way I have the main switched.
There is also a 40 amp Xantrex on-board charger for when 240 v is available.
And a 50 amp dc-dc charger in the vehicle can be connected via Anderson plug to the c/van.
Now to the question. One of the 2 volt batteries has died of old age leaving only 5 siblings.
Buying one replacement 2 v the same size is not an option considering the age of the other five and the price.
What are the options for replacing that quantity of Amp/Hours?.
Is it ok to replace the whole 2 volt bank with a 250 a/h AGM deep cycle or 2 x 120 a/h thus making a mixture of AGM and Gel?
Would I then need to run the AGM independently and also charge it independently to the SunGels ?
Any info is appreciated
Scrubby.
