Baby seat in Land Cruiser DX 80 series
Submitted: Tuesday, Jun 27, 2017 at 18:32
Erik N
Hi Guys,
We have a Toyota Land Cruiser DX 80-series 1996.
It has screwholes in the roof of the cargo area. They seem the anchor points for the baby
seat.
However I'm chasing the right bolt. Both size as
well as safe enough to cary thr weight and force in case of emergency.
Thanks in advance,
Erik
Reply By: Shaker - Tuesday, Jun 27, 2017 at 18:44
Don't the bolts come with the
seat fitting kit?
There would be very strict Australian Standards for this, maybe talk to the
seat manufacturer.
612194
Follow Up By: Erik N - Tuesday, Jun 27, 2017 at 23:14
The bolts supplied with it are too thick . The bolts used for the cargo barrier are too big??
882340
Reply By: Dean K3 - Tuesday, Jun 27, 2017 at 20:03
Capsule mounts will be either in rear of upright
seat section and uses a little hook to attach capsule tether to.
OR
Bolts into floor
Never known any capsule mounts to be bolted to the roof, put it this way in event of a rollover or severe head on impact the roof crushing in you want the tethers of capsule to remain tight and secure not loosen allowing capsule to fly freely.
go to a dedicated baby supply
shop they will have the correct fittings and graded bolts or toyota can assist - don't risk safety of a infant/child period
612196
Follow Up By: Erik N - Tuesday, Jun 27, 2017 at 23:17
Good point. As far as our research went. It sounds like it has to go in the roof.
As I want the safest possible,i haven't put it inn yet. As I have not found an appropriate solution.
May indeed have a chat to Toyota.
882341
Follow Up By: Member - Phil G (SA) - Wednesday, Jun 28, 2017 at 00:29
Yep they are in the roof on the 80series - its the way things were in the 90's
882343
Follow Up By: Erik N - Wednesday, Jun 28, 2017 at 17:14
Thanks Phil G,
What bolt did you use? As the one provided is too big for the hole.
The bolt used of the cargo barrier is too fat for the anchor poit supplied with the
seat??
882390
Follow Up By: Member - Phil G (SA) - Wednesday, Jun 28, 2017 at 19:19
Go buy the correct anchor bolt kit from almost any car accessory
shop like Supercheap:
Link Here
It will bolt straight into the roof anchor points on the 80series.
The photo below shows the 80series factory bolt with cover on the left and a SafeandSound one on the right. They both have a 5/16th bolt.
Anchor bolts
882392
Follow Up By: Erik N - Wednesday, Jun 28, 2017 at 21:20
Thanks heaps Phil!!! Nice set up btw if your 200 series!
882398
Follow Up By: Steve D1 - Thursday, Jun 29, 2017 at 20:40
Rav 4's mount in the roof as
882429
Follow Up By: mountainman - Monday, Jul 03, 2017 at 21:56
Go visit a authorized baby
seat installer.
Toyota dont install baby seats.
.the installer will tell you what is required and it will be legally engineered to do the right job for the right baby
seat setup.
mate had his done for under $300 .
Its fully compliant and legal
cheap when you need to stuff around and still guess is my baby
seat secured properly.
882539
Follow Up By: Member - Phil G (SA) - Monday, Jul 03, 2017 at 23:26
The 80 series has 3 factory mounting points already.
882546
Reply By: nickb - Wednesday, Jun 28, 2017 at 16:15
If you have no luck, I had one installed and certified into the roof of my Patrol by Wilkinsons in
Adelaide. Cost was around $200 but this was about 7 years ago.
612211
Follow Up By: Erik N - Wednesday, Jun 28, 2017 at 17:15
Thanks mate,unfortunately I'm based in Victoria,just outside
Melbourne.
882391
