Sarina mechanic?
Submitted: Monday, Jun 12, 2017 at 18:15
ThreadID: 135072 Views:3201 Replies:4 FollowUps:2
Hi forumites, we are headed for Sarina for several days and hope someone knows a good mechanic in town please? The Pajero injectors need doing and expect most of the day will be involved and I am hoping to avoid sitting around at Mackay for the duration. But will if need to. Thanks. Phil
Phil 'n Jill (WA)
Reply By: Deejay - Monday, Jun 12, 2017 at 22:02
As an ex diesel fitter, I'd be skipping the mechanic and going straight to a dedicated injection specialist.
AnswerID: 611861
Reply By: Member - Phil 'n Jill (WA) - Tuesday, Jun 13, 2017 at 09:00
Thanks for the tip, I hadn't thought of that as an option. My local mechanic who maintained my vehicles for thirty years was very good, but ill health caused him to close shop. He was particular with the injectors and I guess not all workshops will have the same ethics. I will consider that if I don't get a reccomendation. Cheers ?? Phil
Phil 'n Jill (WA)
AnswerID: 611865
Reply By: Batt's - Tuesday, Jun 13, 2017 at 12:27
What's wrong with the injectors
AnswerID: 611869
Follow Up By: Member - Phil 'n Jill (WA) - Tuesday, Jun 13, 2017 at 15:14
Sorry, I will rephrase the issue.
Finally dug the service book out from it's new hidey place and see the service requires attention to 'valve clearance ' which I understand deals with tappet servicing and think it involves removal of the injectors or pipes and is fairly time consuming. The more I research it on the Pajeroforum the more convinvced I am that the job needs to be done properly, so if necessary I will go to Mackay for the day as recommended below.
Thanks , Phil
Phil 'n Jill (WA)
FollowupID: 881917
Reply By: Injected - Tuesday, Jun 13, 2017 at 14:43
Brendan Cook from Diesel Power unlimited in Mackay would be your best bet. Failing that On Track Diesel would be the next choice.
AnswerID: 611870
Follow Up By: Batt's - Tuesday, Jun 13, 2017 at 20:52
No worries probably a good idea to go with a recommended company I live in mackay but haven't needed any work done sorry I can't help there.
FollowupID: 881923
