Wednesday, Oct 25, 2017 at 21:15
Guys, I've just looked at this - finally!!!
...sorry I'm a single dad and I have my kids every weekend so it's impossible to work on my vehicle with
young kids sticking screw drivers in my tires and their ears cause I'm working on my truck.
So this basically got so bad that I'd push the clutch in and people on the footpath would look sideways at my vehicle. The problem was the clutch
fork pivot ball needed a bit of grease and a small amount has fixed the problem. Given it's a Landcruiser the pivot ball is accessible and this is a very quick and simple job.
Here's
the steps you need to take:
1) Degrease and clean up the clutch slave cylinder and hydraulic line - in my case this took more time than all the other steps combined.
2) Crack both 12mm bolts on the slave cylinder.
3) Clamp the brake line and I get a roll on duct tape handy cause I'm going to tape the shaft to the cylinder so it doesn't push out of the cylinder.
4) Undo the two bolts on the slave cylinder and tape it up so the piston seals don't get damaged traveling too far forward in the cylinder where they don't normally travel and where there's probably corrosion or pop put.
5) Remove the rubber boot from the clutch
fork and you should be able to see the pivot point if you pull the
fork towards the rear of the vehicle.
6) I had a long brush (about 400mm) and put a
little red grease (water and heat resistant) on it and transferred it to the contact point between the
fork and the pivot. I only used about as much as you would use toothpaste on your tooth brush cause I'm paranoid about getting grease near my clutch.
7) Re-install the rubber boot.
8) Remove the duct tape and torque the slave cylinder back up.
9) Grease the contact point between the slave cylinder shaft and the clutch
fork.
10) Road
test.
In my case the noise was completely gone.
Thanks to the moderator's for unlocking this post so I could reply back to this - my apologies for the delay in getting to this.
I hope this post helps someone else in the future!!!
614592
