Monday, May 15, 2017 at 20:55
Ben, good call as some turboed ok and others didn't, some had problems with the head in the way they were manufactured but no one I knew could put a finger on it.
I drove many 47's and 75's without a/c and just opened the quarter vents. Guess if you haven't got it you just keep on keeping on, until the 80's I never had an a/c in a truck either.
if you decide to install a/c and need a bit more get up and go, I just used to say hit the turbo button (turn off the a/c). you only need to do that if you were on a steep
hill or overtaking. For some reason some of those old girls could get along
well. My last one could hit 140kph and that was on flat ground with no tail wind.Then again I can remember being the escort in a 47 series for some long loads and once we hit 100kph in open country I had to tuck in behind and tailgate the lead truck so I didn't get run over.
Check the front drive shaft for wear. Because most of the time the shaft is just sitting still the splines the slip joint wear, if you push it up and down you will feel it. Fill the front axle ball joints with heavy duty lithium greased made replace the ball joint wipers.
Check the gearbox and transfer case oil levels as they had a bad habit of pumping oil through the seal and daring one while over filling the other. Also put her in 4wd low range and listen for noises coming from the transfer case and trust me you will hear it if it its u/s. The idler gear in those old girls had a problem with case hardening on the idler gear shaft and caught early it was not problem and easy to fix, if let go you might as
well install a new transfer case.
It probably has an after market muffler but a low restriction turbo muffler really helped their performance by about half a gear on a
hill.
Don't be deterred by what I have said as they were a great vehicle.
881145
