Putty road
Submitted: Wednesday, May 10, 2017 at 10:39
Member - neville G (QLD)
Question, I am currently in Temora and want to travel to Forster, towing caravan. Does anyone have knowledge of the
Putty road?
Thanks in advance....Neville
Reply By: Member - Rod N (QLD) - Wednesday, May 10, 2017 at 10:58
It's a 2 lane sealed road. A bit windy and hilly. We towed a van through there with no problems. If your rig is within limits you should have no problems even with a large van.
610995
Reply By: Gundarooster - Wednesday, May 10, 2017 at 11:52
Neville,
The
Putty road is a good run but will be slow with a van, another alternative if traveling from Temora would be the
Bylong Valley. Anythings got to be better than Pennant Hills Rd as it's pretty much a car
park 24 x 7!
Gazza
610996
Reply By: Member - Kevin S12 - Wednesday, May 10, 2017 at 12:11
I towed Avan thru there last year with no problems. Few hills and winding road. Call into the
Grey Gum Café...plenty of room for overnight with big firepits.
610997
Reply By: Member - neville G (QLD) - Wednesday, May 10, 2017 at 17:38
Thanks very much for the reply,s, looks good and as they say "lock it in"
Cheers, Nev.
611004
Reply By: Lindsaydi - Wednesday, May 10, 2017 at 21:51
Towed a 21ft Lotus Trooper down the
Putty 6 weeks ago piece of cake. Not like it was the first time in 69. Some interesting
places to stop including the closed servo.
611016
Reply By: Gronk - Thursday, May 11, 2017 at 06:49
I personally don't like the
Putty road. Not because you can't easily tow along it, but for the endless 40k/ph sharp corners. OK if you have plenty of time, but I always stick to the main hwy if travelling south from the nth coast.
Pennant Hills rd is only very busy during peak times, so avoid it then and no probs at all.
611026
Follow Up By: Baz - The Landy - Thursday, May 11, 2017 at 07:06
"Pennant Hills rd is only very busy during peak times, so avoid it then and no probs at all."
As a local that uses Pennant Hills Road daily I must say you are right, avoid in peak times, problem is these days that is about 20 hours a day!
Cheers, Baz - The Landy
880997
Follow Up By: Gronk - Thursday, May 11, 2017 at 21:47
Ha ha, I know what you mean, but I usually don't have a problem with it the times I go south
camping from the central coast.....which is approx 3pm of a friday, just before peak time.
I find the most annoying bit is that short bit from the M2 to the M7.......then the stupid 100 k/ph limit on the M7, which is the best piece of freeway in
Sydney ?
881030
