Friday, May 05, 2017 at 18:31
Read you are towing, so would expect about that especially if hilly terrain in your initial short drives.
I assume you were towing on those drives ?
For sure the wind direction and strength is either a godsend or a curse, with or without something hitched up !!
My tank when topped off stays there until I've done pretty much 400km, when the needle is right on the gauge full mark.
I know then I have a safe 80lt up my sleeve.
From the full mark, the gauge goes down relatively evenly per 1/4 marks on the gauge, usually about 20lt per mark, so on blacktop drives without a lot of terrain, no wind to speak of, and siting on 100 / 110, I get around the 800km range on top of the first 400km.
I'd be looking at ways to better tune the engine for best economy.
Maybe a chip / exhaust will help with the towing, allow you to not push it as hard, have some up your sleeve power wise, you just have to drive them easy as with better power / torque people sometimes 'use' it instead of nursing along, and use same or more in fuel / 100.
It's hard to say if you could / should be getting much better than high teens with your caravan, there are so many variables with weights, if an auto and may be better towing out of overdrive, etc.
I know if I do around the limit I get low to high 10s, if I drop to 90 I get about 0.5 to 1lt better econ, it's usually not worth worrying about.
It might take you a trip or three more to get the feel for things, best way to use the
Ranger gearing, right pedal, etc.
880819
