Flared Guard Seal
Submitted: Monday, May 01, 2017 at 16:27
ThreadID: 134774 Views:5172 Replies:4 FollowUps:2
G'day everyone.
I've owned a '99 HZJ75 Troopy for as long as I can remember and it has TJM Deluxe Flares and the rubber between the flare and the body work needs to be replaced.
Is anyone aware where I can buy this (I phoned TJM and they told me to talk to one of their dealers - not very helpful).
Reply By: Member - mechpete - Monday, May 01, 2017 at 17:23
have you tried Clark Rubber
they have a good selection
cheers mechpete
AnswerID: 610722
Reply By: Member - Phil G (SA) - Monday, May 01, 2017 at 17:34
I think its a P section extrusion - can get it from Clark Rubber in 2 sizes:
Clark Rubber extrusion
AnswerID: 610723
Reply By: Hoyks - Monday, May 01, 2017 at 18:07
Try eBay. Searching for 'arch flare seal' gets a few results and for a fraction what Clark will charge.
AnswerID: 610726
Reply By: Manic - Tuesday, May 02, 2017 at 08:00
Thanks for the replies everyone.
It's actually a h section that's used on those flares and I've tracked the stuff down.
AnswerID: 610735
Follow Up By: Member - ACD 1 - Tuesday, May 02, 2017 at 09:32
Can you let us know where (or is it a secret???)
The info may help someone else - and sort of completes the post.
Anthony
FollowupID: 880696
Follow Up By: Manic - Tuesday, May 02, 2017 at 10:39
Yep, the solution was to search eBay but the 'trick' was the search criteria that Hoyks posted up.
Use 'arch flare seal' and you'll find all the listings and the different types of seal.
This is the type for mine: http://www.ebay.com.au/itm/h-Fender-Flare-Trim-to-suit-Wheel-Arch-Flares-2-x-1-5mtr-Suits-most-4WD-/121798646999?hash=item1c5bc3dcd7:g:XKUAAOSw5VFWLrnm#vi-ilComp
FollowupID: 880700
