As we head into cold days and nights and think about the comfort of heating, this week is Carbon Monoxide Awareness Week. Time to
check that appliances you are using at
home are
well maintained and operating safely.
For those travelling, don’t be tempted to use any unflued heating in your caravan or camper, nor ideas bandied around like an upturned flowerpot over a gas burner.
In addition to having your indoor solid fuel or gas heater serviced, use a Carbon Monoxide alarm as an added defence. This is not a substitute unserviced heaters, or an excuse for using an outdoor form of heating indoors.
Carbon Monoxide Awareness week, to be held from 1st to 7th May 2017.
The aim of Carbon Monoxide Awareness Week is to raise awareness of carbon monoxide poisoning across Australia, and to advise on preventative measures that people can take to reduce the risk.
The Chase and Tyler Foundation raises awareness of carbon monoxide poisoning in Australia.
Some common products that can emit carbon monoxide when you use them are:
• Barbeques that use wood, charcoal or gas
• Fireplaces that use wood, charcoal or gas
• Portable cookers that use gas or kerosene
• Portable and/or outdoor heaters that use gas or kerosene
• Flued gas heaters (under certain conditions)
• Electrical generators that are diesel or petrol powered
• Electrical equipment that is diesel or petrol powered (such as pumps, chainsaws, blowers and welders).
Safety Tips
• Never use the above listed products inside the house or in areas that are not
well ventilated, such as enclosed patios, garages and sheds, greenhouses, tents and caravans.
• If you have an indoor fuel heater, consider having it checked by a licensed professional at the start of winter to ensure it is not producing excess carbon monoxide.
• If you have a fireplace, ensure that the
chimney has no blockages before you start using it.
• Similarly, if you have a wood heater ensure the exhaust vent pipe is free of blockages.
• If you are camping and need to use portable cookers, heaters and barbeques in a covered area (for example, if it’s raining), make sure that the area is
well ventilated.
• In an emergency situation or power blackout where you need to use items such as electrical generators and portable heaters, ensure that the area they are being used in is
well ventilated.
From
Product Safety
At higher levels, carbon monoxide can kill within minutes. Even if you get fresh air in time to save your life, carbon monoxide can cause strokes, heart attacks, memory loss and personality changes. This brain damage is permanent.
Despite the warnings, people die every year throughout the world due to accidental carbon monoxide poisoning. Disability suffered by carbon monoxide poisoning survivors is rarely reported.
For camping off mains power in really cold weather, either a diesel heater (Webasto, Dometic or Eberspacher or cheaper copies), or installed gas heater (Truma) are the best options for heating your caravan.
You can get 12 volt electric blankets or use a 240 volt one off your inverter to warm the bed, or pull on Explorer or other thick woollen socks, and use a zero rated sleeping bag to keep the warmth you generate close around you.
